Grub screw removal
  • ruggerbloke
  • Junior Member
  • Junior Member
22 Dec 2020 17:52 #23891 by ruggerbloke
Grub screw removal was created by ruggerbloke
My Torque 2814 motor had a coming together with the ground. When I unscrewed the four screws holding on the Prop driver/shaft, one of the screws sheared. Another one had the hex head worn into a circle. To get the shaft off I had to cut it off with a dremel. No problem. I thought I'd use a collet type shaft instead. My problem now is that the two grub screws holding the shaft in place have also got rounded heads and all attempts to remove them using hex wrenches have failed. What is the best way of doing this? I think with my drill I am likely to knacker the whole thing. Advice appreciated. Cheers
22 Dec 2020 18:27 #23892 by kevinross
Replied by kevinross on topic Grub screw removal
Hi Dennis
Is this your motor ?
I see two approaches
1 - Try to drill out the screw but this would need high quality drill (cobalt or equivalent). Then use an easy out (screw extractor) The secret of drilling hard steel is slow speed, coolant and pressure so access to a pillar drill would be a great help.
2. - Last resort would be to hack saw at 90deg to the collar to create a slot in the screw. If this is successful try to drill a replacement new hole and tapping to the correct size.
If you are successful you need to strip the motor to remove any swarf.
  • ruggerbloke
  • Junior Member
  • Junior Member
22 Dec 2020 18:49 #23893 by ruggerbloke
Replied by ruggerbloke on topic Grub screw removal
Hi Kevin, thanks for your advice. Yes, that's the motor. I am thinking now of trying to get a new Bolt on prop adapter for the motor. I just hope the shaft is not bent! If it is I'll try the method you suggested. Cheers
22 Dec 2020 20:02 #23894 by John Bannister
Replied by John Bannister on topic Grub screw removal
Denis problem with the grub screws is that they were locktighted in you need to get a small blowtorch just to warm up the end of the motor not to much or you will damage the bearing and motor windings and you will find the grubscrews will come out easily.
  • ruggerbloke
  • Junior Member
  • Junior Member
22 Dec 2020 20:34 #23895 by ruggerbloke
Thanks John for the info. Yes they were locktited in. The problem is that the hex head is now more like a circle so the hex driver has no grip.
23 Dec 2020 07:21 #23896 by kevinross
Hi Dennis
John B's heat advise is good . I had thought about suggesting that and no offence but I don't know your capabilities and a blow torch in the wrong hands could spell disaster so I will add that if you have some scrap sheet metal you could drill out to clear the red boss , that would protect the motor and get the heat to the right place
I've since thought of another tip I've used before
Take a larger size Allen key and cut off the bend . Then grind small tapers on each of the six flats so you can tap it into the damaged screw socket then twist with mole grips or similar
  • ruggerbloke
  • Junior Member
  • Junior Member
23 Dec 2020 09:00 #23898 by ruggerbloke
Thanks again Kevin. I'll have another look this morning in the cold light of day and consider all options. This forum is invaluable for help from so many experienced modellers/engineers. Thank you all.
  • Chris Hughes
23 Dec 2020 12:37 #23904 by Chris Hughes
Replied by Chris Hughes on topic Grub screw removal
A safer option than a blow torch is to use a soldering iron, just hold the tip of the iron on the grub screw, that way you are only heating the bit that you want heat on
23 Dec 2020 15:27 #23905 by DaveBright
Replied by DaveBright on topic Grub screw removal
Chris Hughes wrote: A safer option than a blow torch is to use a soldering iron, just hold the tip of the iron on the grub screw, that way you are only heating the bit that you want heat on
This is how I soften loctite too.... blue and occasionally the red stuff if used in error :-)
  • ruggerbloke
  • Junior Member
  • Junior Member
23 Dec 2020 17:08 #23906 by ruggerbloke
Thanks to everyone that took the time to reply. It's nice to know that everyone, regardless of experience has come up against this type of problem in the past. Cheers all.
