Grub screw removal
23 Dec 2020 19:50 #23907 by JRI
Replied by JRI on topic Grub screw removal
A popular method seems to be to use a tungsten carbide drill into the remaining head of the grub screw, then gently hammer in a torx screwdriver bit, apply heat to the bit using a soldering iron, then attach the screwdriver body and it should remove easily.
  • ruggerbloke
  • Junior Member
  • Junior Member
24 Dec 2020 09:32 #23908 by ruggerbloke
Replied by ruggerbloke on topic Grub screw removal
Thanks all. I have now managed to find a front fixing prop driver that fits. All tested and the propshaft luckily is not bent to no need to remove grubscrews now. Result! Thanks for all your input.
24 Dec 2020 13:15 #23910 by kevinross
Replied by kevinross on topic Grub screw removal
After all the encouragement we offered to assist wrecking your motor - you've taken the wimps way out !!
- actually good result Dennis
24 Dec 2020 14:43 - 24 Dec 2020 14:43 #23911 by Phil Ford
Replied by Phil Ford on topic Grub screw removal
Kevin Ross wrote: After all the encouragement we offered to assist wrecking your motor - you've taken the wimps way out !!
:huh: :lol:
Last edit: 24 Dec 2020 14:43 by Phil Ford.
  • ruggerbloke
  • Junior Member
  • Junior Member
24 Dec 2020 17:22 #23914 by ruggerbloke
Indeed Kevin. Thanks to you all the other guys for their input. Will be seen soon at Cashmoor for more interesting episodes. A Merry Christmas and Happy New Year to all members. Cheers!
  • Brian Jackson
25 Dec 2020 10:15 #23915 by Brian Jackson
Replied by Brian Jackson on topic Grub screw removal
Another "last resort" but needs the use of a grinding wheel. Get the correct size Allen key, quickly "dab" the long end of the key on the grinding wheel, this allows a useful burr to form, don't be too gentle or you won't get a burr. Line up the key with what's left of the hex socket, push in firmly. The burr folds back and forms a fairly tight fit in the socket.
Time to create page: 0.363 seconds
