Spark damage...and prevention
01 Apr 2016 12:32 - 01 Apr 2016 12:33 #8453 by JonTappin
Replied by JonTappin on topic Spark damage...and prevention
MikeSeale wrote:
JonTappin wrote: Makes me wonder if you have an issue with your esc Mike?
I appreciate that it is my ESC. However, the fact that anti-spark connectors are made indicates that I am not the only one experiencing this issue. The fix is simple and completely removes the spark.
I understand that, my concern was that your spark is doing so much damage to the connector, I'm not sure that is normal. Also if I understand correctly, it has just started doing this recently.
Last edit: 01 Apr 2016 12:33 by JonTappin.
01 Apr 2016 12:51 #8454 by MikeSeale
Replied by MikeSeale on topic Spark damage...and prevention
The ESC is the same type (EMAX Simon Series 80A) that I have in the Blue Angel, but not the same ESC. This new ESC has sparked a lot since new...perhaps the first spark damaged a component in the PCB and subsequent sparks have made it worse. Once it is connected it seems to run fine...
...however, it does seem to take a long time getting to the arming sequence. I've got a spare so will swap it over and see if it makes a difference. But I'll make the anti-spark modification because this only has to be soldered once instead of regularly replacing connectors
Time to create page: 0.262 seconds
