Lipo Charging Fire
21 Jun 2016 17:20 #9076 by kevinross
Replied by kevinross on topic Lipo Charging Fire
Your description of the damage did not prepare me for the photos and very sorry you experienced this. If you imagine how many Lipo's charges occur each year by UK modellers, your experience is probably one in a million but it shows that charging near combustable material has to be avoided. Its easy to understand how complete garages and houses could be destroyed.
PS - some people suggest that if you charge in an ammo box - it should be vented in such a way to disperse the explosive effects in a safe direction.
21 Jun 2016 17:41 #9077 by Chris001
Replied by Chris001 on topic Lipo Charging Fire
So what are the chances of two people at our club having a similar incident a week apart? Luckily the other one was outside on a patio, not in a shed or house.
  • JonTappin
21 Jun 2016 18:53 #9078 by JonTappin
Replied by JonTappin on topic Lipo Charging Fire
Not you as well Chris?
21 Jun 2016 19:20 #9079 by Chris001
No not me, Phil and Andy had a shot a bit of video of a LiPo on fire and smoking like crazy on their patio, I was shown the video on the Saturday when we had the council guys up, and I think it was a battery they were charging in readiness for that day. It prompted me to start looking at how I charge and store my batteries, but like an idiot it took your unfortunate incident to actually get me to pull my finger out and do something.
22 Jun 2016 08:24 #9081 by flyingpete
Replied by flyingpete on topic Lipo Charging Fire
Just seen your post Jon! Sooooooo sorry to see the damage done by the fire.
Iv seen the damage done by a lipo fire first hand before,as a few years back a mate of mine lost his double garage,two cars and 28 models!
  • JonTappin
22 Jun 2016 08:49 #9082 by JonTappin
I've heard several similar stories before and since my incident, it is easy to think it will never happen to you, I now know differently :(
22 Jun 2016 11:14 #9083 by MikeSeale
Replied by MikeSeale on topic Lipo Charging Fire
Can you confirm the following, Jon.
What program were you using on your charger (normal charge, fast charge, balance charge...)?
Did you have the balance lead attached?
Did you check the voltages of each cell as soon as it started to charge? ie. all cells were about the same voltage before you left it charging?
22 Jun 2016 12:11 #9085 by Dante
Replied by Dante on topic Lipo Charging Fire
Well for what's worth, Phil Williams has had two batteries go up in the last few months, that's taking a rare risk a little too far!! There are now LiIo (lithium Ion) batteries that have an internal circuit inbuilt that do not need a balance board - Jeti for one - furthermore think of all the LiIo batteries on rechargeable tools, drills especially, which have used LiIo batteries for many years now and no balance leads required. That technology has been around for years. Maybe it's time we all looked more seriously at using LiIo batteries instead of Lipos?? Not sure how high capacities go to but an investigation would be sensible.
  • JonTappin
22 Jun 2016 12:54 #9086 by JonTappin
MikeSeale wrote: Can you confirm the following, Jon.
Hi Mike
Standard balance charge at 1c using a Thunderpower charger, 610C. I didn't specifically check each cell voltage but the charger will not start if the individual cell voltages are too different, I know this as I have had this warning come up on some old packs previously, the charge wouldn't start until I had reduced the imbalance.
22 Jun 2016 17:52 - 22 Jun 2016 17:55 #9091 by kevinross
Dante wrote: Well for what's worth, Phil Williams has had two batteries go up in the last few months, that's taking a rare risk a little too far!! There are now LiIo (lithium Ion) batteries that have an internal circuit inbuilt that do not need a balance board - Jeti for one - furthermore think of all the LiIo batteries on rechargeable tools, drills especially, which have used LiIo batteries for many years now and no balance leads required. That technology has been around for years. Maybe it's time we all looked more seriously at using LiIo batteries instead of Lipos?? Not sure how high capacities go to but an investigation would be sensible.
Dante - think you will find most power tool Liion batteries have built in PCB balancer / low voltage cut out. However that technology has historically not delivered the equivalent Power / weight / volume advantages as Lipo. This is changing but at a cost.
Last edit: 22 Jun 2016 17:55 by kevinross.
Time to create page: 0.338 seconds
