8 years 10 months ago #11019 by Phil Ford
G_O_L_D wrote: Note to self = careful on eBay sales, shame as I've had some real good begins on there !
I generally take the attitude that if it is being sold on Ebay it's probably not even decent enough to sell on BMFA classifieds, where at least there are real RC flyers. I found this too a few years ago when purchasing a Carl Goldberg Chipmunk from Ebay. Looked good in the pictures at least. Lesson learnt!
8 years 10 months ago #11021 by Phil Ford
Here you go Lee, running happily. ;) A couple of minutes of playing and then dive back indoors. That's my bit done!
Two degrees and a breezy easterly - feels like -2 deg. I'm staying in for the rest of the day. Brrr.
8 years 10 months ago #11023 by JonTappin
Replied by JonTappin on topic Help required OS 70 - 4 Stoke (Acro WOT)
Nice one Phil B)
8 years 10 months ago #11032 by
PhilF51 wrote: Here you go Lee, running happily. ;) A couple of minutes of playing and then dive back indoors. That's my bit done!
Phil ur a diamond ! ty so much hopefully the COWL will do on with new engine, if not easy to get or tinker with
8 years 10 months ago #11034 by Phil Ford
Theoretically, as the cowl has previously been cut for the mixture screw to be upwards, the norm in my opinion the cowl will fit nicely. Why anybody would want to have to kneel down and reach under the cowl and near a spinning prop to adjust the screw is anybody's guess. The only thing you may have to do is the adjust the angle of the exhaust header (manifold in English GB ;) ).
On my Wots Wot the cowl comes off with out having to remove any items, it just clears everything. You won't know till you refit the cowl though.
8 years 10 months ago - 8 years 10 months ago #11035 by
PhilF51 wrote: ...On my Wots Wot the cowl comes off with out having to remove any items, it just clears everything...
Blimey Phil, what size of prop and spinner are you using on your Wots Wot? ;)
Last edit: 8 years 10 months ago by .
