Tricky choke location
22 Jul 2017 15:09 #13367 by DavidTappin
Replied by DavidTappin on topic Tricky choke location
How about dispensing with the butterfly choke, just leaving it open, and install some sort of external pad working the old fashioned way, just like putting your finger over the carb? As the tanks is so close it could be mounted on the tank with a vertical pusher to operate it against a spring which would keep it normally open. The top of the pusher could reside flush with the fuselage when the choke is open and be depressed with a suitable plunger against the spring to hold the "choke" closed while starting the motor.
22 Jul 2017 17:23 - 22 Jul 2017 17:29 #13368 by kevinross
Replied by kevinross on topic Tricky choke location
Not giving up yet JRI
Could you cut a small slot in the bulkhead to allow fitting one of these ball links to the choke lever, Then fit this quick release ball connector with tweezers if required. Its a Sullivan product .
I have previously reduced the height and or changed the actuation angle using a slotted bracket mounted under the choke arm as in pic 4953
Last edit: 22 Jul 2017 17:29 by kevinross.
  • JRI
22 Jul 2017 18:31 #13369 by JRI
Replied by JRI on topic Tricky choke location
Thank you all for your worthwhile suggestions. I have solved the conundrum by removing the choke shaft and grinding a new ball-bearing detente and groove in it - enabling me to put the shaft in from the other end of the carb so that the choke lever is now in the same plane and close to the throttle lever. It can now be operated by a push-rod from a servo mounted in a normal location in the fus'.
That was about 10 hours of thinking and experimentation just to solve such an apparently simple problem. I have probably now timed-out for getting the model ready to fly on scale weekend but I enjoyed the challenge.
22 Jul 2017 18:41 #13370 by Phil Ford
Replied by Phil Ford on topic Tricky choke location
JRI wrote: That was about 10 hours of thinking and experimentation just to solve such an apparently simple problem. I have probably now timed-out for getting the model ready to fly on scale weekend but I enjoyed the challenge.
Not necessarily John, you got 6 evenings left.
  • JRI
23 Jul 2017 17:22 #13373 by JRI
Finally, carby controls in place and operational - lots of fiddling to screw in servos etc. Picture shows how far down in the fus' I was operating.
23 Jul 2017 17:38 #13374 by flyingpete
Replied by flyingpete on topic Tricky choke location
Great stuff John, can't wait to see her next weekend
23 Jul 2017 18:54 #13375 by JonTappin
Replied by JonTappin on topic Tricky choke location
Hi John
Glad you sorted it.
On a different subject, so you think you will have enough cooling to the manifold and exhaust? The manifold is very close to the bulkhead where it comes through and you seem to have only a small hole on the other side to get some air in the rear section of the fus.
Might be that it isn't clear from the photos.
23 Jul 2017 19:23 - 23 Jul 2017 19:28 #13376 by kevinross
JonTappin wrote: Hi John
Glad you sorted it.
Also wondering about the fuel tank proximity to the exhaust manifold - or have you planned to employ some form of heat shield from your jet spares box ?
Last edit: 23 Jul 2017 19:28 by kevinross.
  • JRI
23 Jul 2017 19:27 - 23 Jul 2017 19:47 #13377 by JRI
Glad you sorted it.
Might be that it isn't clear from the photos.[/quote]
I will take additional advice from you guys on the subject of airflow - the following pic's explain my cunning plan...
The frontal aspect shows the two air intakes which i am relying on to receive forced air from prop-wash to provide flow..
The next picture shows vents which I have put into the wing to scavenge air from the inside of the fus' to the scoop below...
The scoop has a backward facing exit which I hoping will 'suck' air through the fus due to the low pressure caused by passing airflow...
Am I being a bit optimistic with this 'scientific' expectation that air will flow through the fus and keep the internal tuned pipe cool?
Last edit: 23 Jul 2017 19:47 by JRI.
  • JRI
23 Jul 2017 21:10 - 23 Jul 2017 21:11 #13378 by JRI
The vents are through holes in the wing from the fus interior to the scoop, The big holes are for the retracts!
Last edit: 23 Jul 2017 21:11 by JRI.
Time to create page: 0.450 seconds
