New Toy
21 Mar 2018 08:40 #16117 by Brian
Replied by Brian on topic New Toy
Some years ago, Pacer brought out a water based hinge glue. It was in a small bottle and quite expensive. It was easy to use and I never had any problem with it. By the time I'd finished the first bottle, Pacer had stopped supplying it. I emailed them to see if I could get some direct from the U.S.. The reply was prompt and stated that American modellers (modelers?) had found that Pacer Canopy Glue did the job even better and was a lot cheaper. I've used canopy glue ever since. Clean up with water. Never had a sticky hinge. For flat "pinned" hinges, I drill part way with a Robart hinge jig, cut the slot in the usual way, the hole is for the glue bottle nozzle, makes filling the hinge slot fool proof.
21 Mar 2018 09:38 #16119 by JonTappin
Replied by JonTappin on topic New Toy
When I originally built my EF Edge 50cc, I hinged with Robarts and pva, very easy to do. But within a few months some started to loosen. I managed to pull them all out and reglued them all with epoxy.
It may be that I didn't use enough glue or that with extreme 3d movements it's not up to the job.
I am not planning to use pva again, don't like doing the same job twice!
21 Mar 2018 21:50 #16125 by Chris73
Replied by Chris73 on topic New Toy
Only managed to get a couple of hours on the plane tonight
So decided to get a few of the smaller jobs done
Tail wheel was disassembled and then reassembled using blue loctite on all screws, then got the fuel dot fitted and plumbed the fuel tank
21 Mar 2018 21:54 #16126 by Chris73
Some people have had problems with the supplied hardware, so not wanting to risk it, all control rods and ball links were replaced with Secraft ones
Dont know if it was needed, and I have always used the hardware supplied from Extreme Flight in the past, but didnt want to find out the hard way that there was an issue
21 Mar 2018 21:57 #16127 by Chris73
Nest job was to make up the extension leads for the elevators and rudder, I use Powerbox cable and crimps, and then braid all cables to prevent them from rubbing against anything
21 Mar 2018 22:01 #16128 by Chris73
Final job for this evening was to install the elevator servos and make up the control linkages (Installing the servo wasn't fiddly at all :( )
I use two drill bits the correct size to make screwing the ball links on easier
22 Mar 2018 18:37 #16132 by simondean
Replied by simondean on topic New Toy
Can't believe your not done yet! The Extra was finished overnight!
22 Mar 2018 18:51 - 22 Mar 2018 18:52 #16133 by Phil Ford
Replied by Phil Ford on topic New Toy
simondean wrote: Can't believe your not done yet! The Extra was finished overnight!
:lol:
Mind now Simon your on sticky ground there - your project and progress.;)
Last edit: 22 Mar 2018 18:52 by Phil Ford.
22 Mar 2018 18:59 #16134 by Chris73
If I didn’t have to work it would be done by now
22 Mar 2018 20:37 #16135 by Chris73
Little bit more progress tonight, made the extension leads for the ailerons, and fitted the servos, I have run out of braid so will have to braid the cables when it turns up (Hopefully tomorrow)
Time to create page: 0.558 seconds
