DLE 55 Sheared Prop Bolts
18 Jul 2018 22:22 #17202 by Dave Rogers
Replied by Dave Rogers on topic DLE 55 Sheared Prop Bolts
Phil, from experience the best trick ever is to get a vibro etcher, stick it on the end of the sheared bolt , press it in firmly off centre, allow it to vibrate into the bolt then move it around anti clockwise as if you were undoing it and hey presto sheared bolt comes out. I have done this many many times at work and have had 100% success rate even on the tightest sheared bolts
19 Jul 2018 07:22 #17203 by Phil Ford
Replied by Phil Ford on topic DLE 55 Sheared Prop Bolts
I will see if my method works first. if not then will post here again. thanks John , Dave
19 Jul 2018 17:11 #17206 by Phil Ford
All sorted now :woohoo:
There was just a little thread out of the rear of the hub. Using my wife's tweezers very carefully managed to get some thread showing on the drive face. I then tapped the edge of the bolts with a fine pin punch to rotate them enough to get my fingers on them. Lucky they spin in n out easily.;) Thanks to all your suggestions and help.
Going over to Probuild tomorrow for a Miracle Ally spinner. Probuild are out of stock of Menz 23 x 8 but they do have 22x10 which I notice the IMAC boys use. Any reason for this on a DLE55, down 1 inch dia and up the pitch by 2?
19 Jul 2018 18:55 #17207 by Chris73
Replied by Chris73 on topic DLE 55 Sheared Prop Bolts
Phil, I think you are imagining things again!!! , I dont know anybody in IMAC that is using that prop
There are two reasons for using smaller dia and more pitch
1)Smaller dia means lower tip speed which means the prop is quieter
2) More pitch gives you a constant speed and is supposed to help with down line braking
19 Jul 2018 19:02 #17208 by Phil Ford
Maybe I am mistaken but I am sure a certain member I saw with an SBach fitted with a DLE55 or maybe a DA50 used a 22. Oh well, will have to shop around the "net" for a 23x8. A popular size apparently....:(
19 Jul 2018 19:08 #17209 by Chris73
Phil go for 10" or 12" pitch, 8" pitch is like driving in 1st gear
19 Jul 2018 19:23 #17210 by Phil Ford
Chris73 wrote: Phil go for 10" or 12" pitch, 8" pitch is like driving in 1st gear
I will see what Andy has got at Probuild prop wise when I pick up the spinner.
19 Jul 2018 22:04 #17211 by kevinross
Replied by kevinross on topic DLE 55 Sheared Prop Bolts
Phil Ford wrote: Thanks David, I will bear that in mind. Kevin, I believe is away on holiday.
I may try a tiny blob of epoxy on the bolt and a piece of 2mm control rod. hoping I can get at least the bolts proud of the prop driver to get a grip on. The bolts use to spin in easily enough just with fingers. Worth a try, last option drilling.
Yes i'm on hols and just obtained first full internet access - I'll be back Mon 23rd and should be able to remove the bolts 4 U !
20 Jul 2018 14:43 #17216 by Phil Ford
Thanks Kevin and enjoy your holiday. I managed to wind the bolts out myself. Albeit it cost me some extra expense, a new spinner and prop. Although my wife thinks that the need of these items is questionable. :huh:
Time to create page: 0.616 seconds
