DLE 55 Sheared Prop Bolts
7 years 3 months ago #17192 by Phil Ford
Replied by Phil Ford on topic DLE 55 Sheared Prop Bolts
Thanks David, I will bear that in mind. Kevin, I believe is away on holiday.
I may try a tiny blob of epoxy on the bolt and a piece of 2mm control rod. hoping I can get at least the bolts proud of the prop driver to get a grip on. The bolts use to spin in easily enough just with fingers. Worth a try, last option drilling.
7 years 3 months ago #17196 by
Replied by on topic DLE 55 Sheared Prop Bolts
What Sometimes Works Phil is drilling as big a hole as possible in the sheared bolt and epoxying a well fitting rod in the hole and then try winding it out.
7 years 3 months ago - 7 years 3 months ago #17199 by Phil Ford
Simon O wrote: What Sometimes Works Phil is drilling as big a hole as possible in the sheared bolt and epoxying a well fitting rod in the hole and then try winding it out.
Simon have moved your post from Shed Club? to DLE55 thread. I was getting confused momentarily. :lol:
That is my plan but without drilling first. Then if it don't work then the drill method. Then if that don't work then it's an engineering job.
Last edit: 7 years 3 months ago by Phil Ford.
7 years 3 months ago #17201 by JRI
Replied by JRI on topic DLE 55 Sheared Prop Bolts
Phil, I have some easyouts and small dremel drills, I should be able to out your sheared bolts if you can get the model to me!
7 years 3 months ago #17202 by Dave Rogers
Replied by Dave Rogers on topic DLE 55 Sheared Prop Bolts
Phil, from experience the best trick ever is to get a vibro etcher, stick it on the end of the sheared bolt , press it in firmly off centre, allow it to vibrate into the bolt then move it around anti clockwise as if you were undoing it and hey presto sheared bolt comes out. I have done this many many times at work and have had 100% success rate even on the tightest sheared bolts
7 years 3 months ago #17203 by Phil Ford
I will see if my method works first. if not then will post here again. thanks John , Dave
