Carb rebuild kits
  • AlanF
20 Mar 2019 19:07 #19113 by AlanF
Carb rebuild kits was created by AlanF
I need to rebuild the carb on my OS 22 petrol engine. I'm reasonably sure it requires a K10 Wat rebuild kit which I believe Just Engines sell for around 15 quid and they appear to sell a Walbro item. The question is has anyone tried the kits available from ebay, which are presumably Chinese knock-offs, for much cheaper. Any thoughts?.
20 Mar 2019 19:44 #19116 by kevinross
Replied by kevinross on topic Carb rebuild kits
I would consider trying a cheapy if only to see if currents symptoms change.
20 Mar 2019 20:13 #19120 by John Bannister
Replied by John Bannister on topic Carb rebuild kits
I'v used cheap replacement carbs from ebay and they have been as good as the originals .
  • AlanF
20 Mar 2019 20:32 #19122 by AlanF
Replied by AlanF on topic Carb rebuild kits
Thanks chaps, a plan is forming.
20 Mar 2019 20:32 #19123 by Chris73
Replied by Chris73 on topic Carb rebuild kits
If it was me, I would buy it from just engines, you know what you are getting then
The risk of buying a cheap one from ebay is that you dont know if it will work properly, you could then think the problem is something else when it isnt
  • AlanF
20 Mar 2019 20:40 #19125 by AlanF
I get what you're saying Chris - I'll give that some thought. I may have to do the OS 33 as well . If that takes the same kit that will have a bearing on what I do. I think both are WT carbs and the K10 is generic for all WT carbs. Just need to confirm this.
21 Mar 2019 07:25 #19126 by kevinross
Chris73 wrote: If it was me, I would buy it from just engines, you know what you are getting then
With respect, i would check they are genuine OEM parts - they could be sourcing from China !
21 Mar 2019 09:56 - 21 Mar 2019 17:34 #19127 by Phil Ford
Replied by Phil Ford on topic Carb rebuild kits
kevinross wrote: With respect, i would check they are genuine OEM parts - they could be sourcing from China !
Definitely agree there. Otherwise you could be going round in ever increasing circles and achieving nothing.
Without diverting the title thread
Alan, at least your OS starts on chicken stick. Apparently OS recommends electric starters as the ign does not kick in till it senses a 120 rpm. Well they maybe they can send me a starter that will turn my OS over cos my Align starter struggles too. :(
Last edit: 21 Mar 2019 17:34 by Phil Ford.
  • AlanF
21 Mar 2019 10:25 - 21 Mar 2019 10:37 #19128 by AlanF
I've gone for an OEM kit from a lawnmower shop on ebay. I've got oem walbro parts from them before so I think they're trustworthy 12 quid delivered wasn't too bad..
The only time I've used a starter on the 22 was on a dry engine. A good glow style flick with a chicken stick usually gets it going.
I cant turn the 33 with a starter so i'ts always a hand start, again using a glow style flick.
With either engine, assuming it isn't dry, it's usually very easy to hand start it - keeping it running smoothly however... !!!!
EDIT
I'm guessing the ignition is looking for a pulse width below a certain value rather than a particular rpm so a sharp flick should do the trick.
Last edit: 21 Mar 2019 10:37 by AlanF.
21 Mar 2019 14:08 - 21 Mar 2019 17:33 #19129 by Phil Ford
Maybe my flicks are not good flicks...:lol: Whatever I still get knackered just the same as if i had 50 press ups.
Before putting away in the Hangar I thought I would try starting Pennzoil at home. Now not even a kick! Took the plug out and checked for a spark. All good. Carb is either not pumping or something is blocking a jet. Strip down (when I get time) sounds the order of the month. Looks like a carb kit for me too just in case.
Got out Pepsi which has same 33GT engine and it started well and runs nice and it has been standing for 3 months. Maybe that's the way to go, don't use 'em.
Last edit: 21 Mar 2019 17:33 by Phil Ford.
