Carb rebuild kits
21 Mar 2019 17:14 #19136 by MikeSeale
Replied by MikeSeale on topic Carb rebuild kits
Phil Ford wrote: Maybe that's the way to go, don't use 'em.
Most of your models must start first time ;)
  • AlanF
23 Mar 2019 15:47 #19164 by AlanF
Replied by AlanF on topic Carb rebuild kits
This is the kit I got - new parts on the left old on the right. The new metering needle is way bigger than the OS part so is unusable, every thing else looks ok.
So far I've noticed that the fuel screen had a fair amount of grit in it but also the flap valves are very distorted compared to the new part - one valve leaf was not laying flat in the carb. The metering lever seems to be set a bit low but I'm not going to change that just yet. The reed block shows no sign of distorted or badly seated valves.
Anyway, fingers crossed onwards and upwards
23 Mar 2019 16:09 #19165 by kevinross
Replied by kevinross on topic Carb rebuild kits
In case you dont have this detail
www.walbro.com/tech-tips/metering-lever-setting/
  • AlanF
23 Mar 2019 16:32 #19167 by AlanF
Thanks Kevin, I think it's set too low at the moment so if I get lean running after the rebuild I'll reset it.
23 Mar 2019 19:11 #19169 by kevinross
Floppy flaps on the pump section normaly settle when the engine is running. If the needle lever is not set correctly - that could be the problem. - I would adjust to the manual before proceeding.
23 Mar 2019 19:34 #19170 by DaveBright
Replied by DaveBright on topic Carb rebuild kits
Was a day of floppy flaps at ththe field today!!
  • AlanF
23 Mar 2019 19:44 #19172 by AlanF
davidbright wrote: Was a day of floppy flaps at ththe field today!!
Well you can't leave that there Dave, the story must be told.
23 Mar 2019 19:45 - 23 Mar 2019 19:48 #19173 by kevinross
I hope not the sort of flops as happened on Wed
Last edit: 23 Mar 2019 19:48 by kevinross.
24 Mar 2019 16:45 #19178 by DaveBright
I had flap problems with both the Hawk and the Spit and Simon had the same on his Corsair. Made for some heart stopping moments on finals!
  • AlanF
29 Mar 2019 18:59 - 29 Mar 2019 19:00 #19238 by AlanF
So the carb rebuild had very little effect in the end. Setting the low end needle for good transition on the ground still leaves the low end too rich. It was still worth doing for educational purposes however and did reveal that even with 3 levels of filtering the carb fuel screen can still clog up.
One piece of info which my be useful is that I ordered the K20 WAT kit as well and that has both a large and small needle. I haven't tried it yet but it looks to be the right size for my OS 22.
...and it was 2 quid cheaper than the K10 WAT so I've saved even more money toward my Demonstrator replacement. Happy Daze.
Last edit: 29 Mar 2019 19:00 by AlanF.
