Warbirds a plenty
18 Nov 2020 07:07 - 18 Nov 2020 07:08 #23697 by kevinross
Replied by kevinross on topic Warbirds a plenty
when you fit the the Keleo exhaust ring muffler, suggest try to retain as much length as possible in the outlet. These engines spew out huge amounts of black exhaust muck.
Last edit: 18 Nov 2020 07:08 by kevinross.
18 Nov 2020 12:37 #23698 by Phil Ford
Replied by Phil Ford on topic Warbirds a plenty
Dave, where are you sourcing your male and female multi point connectors from?
18 Nov 2020 13:44 #23699 by DaveBright
Replied by DaveBright on topic Warbirds a plenty
4 Max now seem to be the license holder for them currently.
19 Nov 2020 12:14 - 19 Nov 2020 12:35 #23706 by Phil Ford
A bit pricey on 4Max if you only want a couple. They are Molex SL series connectors also were known as AshLok. 2.54 mm pitch with 1 mm pins
eg; 9 Way MaxLoc™ Connector kit (M&F)
Includes 9 pins and 9 sockets (assume everyone gets the pin crimped everytime :whistle: )
RS Online. eg; 5 way Molex Female. 10 pack £2.28. Pins - hundreds for very little money. Although the male version is designed to clip through panels but could easily be modded to screw/clamp down on to something rigid within the airframe.
Although saying that Emotec are even more expensive.
I have loads of female multi-way 1 to 6 single row and some 1 to 6 double row connectors that use JST pins, etc. But these are really for use when connecting to pcb header pins.
I asked Dave because getting fed up fiddling with multiple servo,leads. ;) End of deviation from original title.
Last edit: 19 Nov 2020 12:35 by Phil Ford.
