Control Line
22 Mar 2021 20:04 #24364 by JonTappin
Replied by JonTappin on topic Control Line
Phillip Ford wrote: Is that a kit Jon? I got a little Weston looking for a job and me maybe giving control line a go.
As above Phil, but if you're interested I have a couple of plans of other stunt models in a drawer you're welcome to borrow.
23 Mar 2021 07:31 #24365 by kevinross
Replied by kevinross on topic Control Line
Jon Tappin wrote: First the Ultra Flash repaint and now the 2nd lockdown project is complete!
Control line stunt here I come :)
can't tell for the pics Jon but i seem to recall C/L stunt benefits from right rudder to assist line tension (especially as most of your flying is in knife edge or wing overs in this case)
  • ruggerbloke
  • Junior Member
  • Junior Member
23 Mar 2021 08:49 #24366 by ruggerbloke
Replied by ruggerbloke on topic Control Line
Oh No, what have I started? Good work Jon looking forward to seeing it. What are you powering it with?
My control line building is almost at an end due to lack of decent wood. If anyone wants quarter sheet that weighs the same as an iron bar, please PM me. Not expecting many replies!
23 Mar 2021 08:50 #24367 by JonTappin
Yes Kevin thanks for checking, I have a couple of degrees of right rudder in
23 Mar 2021 08:53 #24368 by JonTappin
Denis Murphy wrote: Oh No, what have I started? Good work Jon looking forward to seeing it. What are you powering it with?
To be fair Denis, I started doing this a couple of years ago, it's only that I've run out of other stuff to do during Covid that I've managed to finish it at last!
OS25 installed, thought it might be less hassle than a diesel
The following user(s) said Thank You: ruggerbloke
23 Mar 2021 10:09 #24369 by Phil Ford
Replied by Phil Ford on topic Control Line
My little Weston is 5.8cc so I am thinking a basic control line model of 40 inch wingspan - does that sound about right? I had a look at some Belair kits but they don't supply all the wood or the plans. So having to buy plans for the "kits" they are selling from Sarik the cost starts to mount up. I may have to buy some more balsa anyway so might just create something myself. :unsure:
23 Mar 2021 12:18 #24370 by JonTappin
40in might be too small, mines 47in with 4cc
23 Mar 2021 19:55 #24376 by John53
Replied by John53 on topic Control Line
My Combat (Dominator) is ready to go. The stunt plane I'm building is nearly there.
24 Mar 2021 10:31 #24379 by Phil Ford
I was looking for something quick and simple and came across this Stunter. The only issue is wing cores although the guy did make use of wings for something else. I can take guess and say the wing span would be around 46 inches. Fuselage and Stab easy. pdf files below. Video of it in action
24 Mar 2021 19:30 #24380 by kevinross
Keep it nice and simple for a first attempt Phil
Time to create page: 0.410 seconds
