wild hare sukhoi 100cc
13 Jun 2014 20:36 #2139 by flyingpete
Replied by flyingpete on topic wild hare sukhoi 100cc
Love the scheme B) B)
  • chris.m
13 Jun 2014 20:37 - 13 Jun 2014 20:37 #2140 by chris.m
Replied by chris.m on topic wild hare sukhoi 100cc
See big wheels on the full size too :P
Last edit: 13 Jun 2014 20:37 by chris.m.
  • chris.m
15 Jun 2014 15:25 #2148 by chris.m
Got the stabs and wings done now! B)
  • chris.m
15 Jun 2014 15:44 #2149 by chris.m
with regards on setting up the duel servos on a "Y" lead in the wing this is how I done it,
First job is to centre servos,
Set the inboard horn length in this case 32mm from the surface of the aileron,
Fit push rod so aileron is centred,
Next is to set outboard horn length for this you need to allow for the taper of the aileron so as a starting point I allowed 1mm,
so the overall length was 33mm from the aileron surface.
The reason for doing this is so that in theory the pivot point of the ball link on the horn's is the same length from the hinge point!
Next is to match the outer servo to the cantered inner servo, after doing this check for binding from centre stick to full deflecting each way.
These settings worked perfect for one wing, the other wing I had to make the outer horn longer to stop binding at full deflection!
There is a little bit of trial and error to get this working, probably took me 3hrs ish to get this set up!! (even more fun with three servos!!!) :lol:
Hope some of this make's sense!!!! :unsure:
  • chris.m
15 Jun 2014 15:48 #2150 by chris.m
15 Jun 2014 19:26 #2154 by flyingpete
Nice work chris B)
22 Jun 2014 10:49 #2209 by DaveBright
Replied by DaveBright on topic wild hare sukhoi 100cc
Another stage nearly done. Thanks Chris.
22 Jun 2014 11:26 #2210 by flyingpete
Nice bit of bling Dave!!we will have to start the sukhoi demo team B)
23 Jun 2014 14:10 #2230 by Dante
Replied by Dante on topic wild hare sukhoi 100cc
Dave, with all the fabulous bling does this mean that we will be seeing you flying regularly at weekends from now on. No more excuses of having crossed threaded your motor head with a spark plug again, how lame is that. :whistle:
Bear in mind that Chris has a really powerful right hook and I'm sure he will not take kindly to any stupid mistakes to his super build work. :ohmy:
  • chris.m
23 Jun 2014 18:20 - 23 Jun 2014 18:20 #2237 by chris.m
Another update, Ian is very kindly making some parts for this, so when they are done I can get the motor in and rudder fitted and finished!
PS the dust is free!!!! ;) :P
Last edit: 23 Jun 2014 18:20 by chris.m.
Time to create page: 0.518 seconds
