Christmas Curare
19 Nov 2015 09:01 - 19 Nov 2015 11:36 #7021 by Phil Ford
Replied by Phil Ford on topic Christmas Curare
DaveBright wrote: How about turnigy electric retracts from HK?
They are have got bad reviews, soft ally legs, nose gear fails most of the time and no anti-jam mechanism, no spare parts, etc, etc. They look good though (as shelf ornaments) ;)
Mike, you are right, looks like Germany again for the retracts that are in stock.
Update: Don't rely on the box picture. :blush:
Yes! Jon it is a blue orange inside after all. :lol: Now should it be IC or EP?
Last edit: 19 Nov 2015 11:36 by Phil Ford.
19 Nov 2015 22:03 #7027 by Chris001
Replied by Chris001 on topic Christmas Curare
Blimey, we really are going to have a lot of classic pattern planes on the field soon. I've not got anywhere fast with my Atlas build and I'm already thinking about the plane to build!
With regards to the Electric IC conundrum, Alan started a thread that explored it from every possible angle wimbornemac.org/forum/propellor-club/666-glow-vs-electric
Personally I'd like to see how an electric version compares the Jon's IC Curare, if you're getting it for nostalgic reasons then it's got to be glow.
19 Nov 2015 23:16 #7029 by Chris001
The only thing about the electric version if you go with the recommended motor is that you quite literally have to take a hammer to it!
20 Nov 2015 09:02 #7031 by Phil Ford
Chris001 wrote: The only thing about the electric version if you go with the recommended motor is that you quite literally have to take a hammer to it!
This version does have a hatch now for battery insertion. The battery size is limited mainly by the width of the "tank area". Also the weight on average is increased by 300 gms using electric. When I get round to assembling it, I will be deciding on motive power but I am leaning towards using the OS55AX extracted from the Cherokee. Plus I only need a Genesis pipe. You'll know when the thread moves to a category... ;)
20 Nov 2015 10:25 #7033 by JonTappin
Replied by JonTappin on topic Christmas Curare
Phil
If it helps your decision, here is a link to a review using an electric set up.
www.sussex-model-centre.co.uk/shopcontent.asp?type=News
20 Nov 2015 10:30 #7034 by JonTappin
If you are having trouble sleeping I could scan my review for you as well :)
20 Nov 2015 10:54 #7035 by Phil Ford
JonTappin wrote: If you are having trouble sleeping I could scan my review for you as well :)
Jon, I had already read that review on Sussex. It was that review that made me plump for the Curare. ;)
How is the tuned pipe located because I assume you have to slide the wing under?
I would be grateful for your review if you could scan it up. I really fancy noise n oil :lol: but somehow electric gives less flight time but it is simpler in use. Decisions decisions :(
20 Nov 2015 18:00 - 20 Nov 2015 18:23 #7036 by JonTappin
As you wish!
Pipe is secured under the wing on a supplied bracket with a cable tie, I leave the pipe attached to the silicon joiner when the wing is off.
Part one of the review, the build (assembly :) )
Last edit: 20 Nov 2015 18:23 by JonTappin.
20 Nov 2015 18:03 - 20 Nov 2015 18:22 #7037 by JonTappin
Part 2, flying
Last edit: 20 Nov 2015 18:22 by JonTappin.
20 Nov 2015 18:42 #7043 by Phil Ford
Ruddy hell Jon! You must have spent all afternoon scanning them in. :lol:
Many thanks. I'll inwardly digest all the text.
There was a caveat though on page 1.5. ;)
Quote"While the Curare can be fitted with optional electric power parts the tuned pipe glow engine evokes the true spirit of this classic R/C design"
Um! I think that sums it up in reality.
Time to create page: 0.364 seconds
