Christmas Curare
20 Nov 2015 18:52 #7045 by JonTappin
Replied by JonTappin on topic Christmas Curare
No problem Phil, working at home today so just took me half an hour at the end of the day. Took me a lot longer to write it!!
That quote was by the Editor, but I think I said something similar in the review.
20 Nov 2015 18:59 - 20 Nov 2015 19:01 #7046 by Phil Ford
Replied by Phil Ford on topic Christmas Curare
Just had an email from Austria - Modellsport Schweighofer. Retracts on their way :)
Now to rumage for some servos...
Topic moved to another category - Gas n Glow ;)
Last edit: 20 Nov 2015 19:01 by Phil Ford.
20 Nov 2015 21:08 #7060 by Chris001
Replied by Chris001 on topic Christmas Curare
Phil, I think if you're going authentic you should use a period correct transmitter :evil:
20 Nov 2015 21:42 #7062 by Phil Ford
Chris001 wrote: Phil, I think if you're going authentic you should use a period correct transmitter :evil:
I wouldn't know what one would look like, say from the 1975 era. 1975 was for me, suped up cars (fun) and women (trouble) but not necessarily in that order. :whistle: This rc flying hobby is relatively new for me too.
21 Nov 2015 08:13 #7067 by DavidTappin
Replied by DavidTappin on topic Christmas Curare
Chris001 recommended
.... and don't forget to wear the flares Phil.
21 Nov 2015 09:29 #7070 by Phil Ford
DavidTappin wrote: Chris001 recommended
Flares! Oh god! don't bring that up. Bear in mind though it was the era of the Lotus Cortina, 3 litre Capri Ghia. :woohoo:
Authentic? what about a 35 mhz or was it 27 mhz then, Tx with a bent aerial and a handful of crystals and big EverReady zinc battery. :lol:
22 Nov 2015 09:49 #7085 by Phil Ford
Anyway staying on track.. :)
Servo choice? I do like Hitec servos especially the G2 digitals because they can be programmed to personal preferences and reversed. And if not metal gears then the Karbonite versions at least. However, they are usually slightly longer or wider than other "standard" servos by a 1 or 2 mm.
JonTappin wrote: JR standard voltage, 5.2kg, 0.21s, £13.50
www.servoshop.co.uk/index.php?pid=JRNESDS589&area=Servo
Or go HV for £17.99
www.servoshop.co.uk/index.php?pid=JRC588HV&area=Servo
I have used the DS589 before and are good servos and plenty of torque at 5.5v. But I may just go for Jon's recommendation but in HV but then I still have to regulate down for the retracts. Um, ! will have to mull this over. :unsure:
Does this model need metal geared servos?
22 Nov 2015 10:28 - 22 Nov 2015 10:39 #7086 by JonTappin
No, small surfaces and relatively small deflections.
Just think about the servos they were using in the '70s!! ;)
I'm using a mixture from my collection of 90's era JR coreless analogue, plastic geared servos.They were the best available at the time but actually only have similar figures to todays standard digi servos, 5-6kg 0.21-0.23 s. Add to that many hours of use!
Last edit: 22 Nov 2015 10:39 by JonTappin.
  • Adrian
22 Nov 2015 10:36 #7087 by Adrian
Replied by Adrian on topic Christmas Curare
does that predate the futaba s148?
22 Nov 2015 13:42 #7088 by JonTappin
Probably from a similar time Ade, that is the classic Futaba standard servo. The spec is a fair bit lower though, 2.4kg and .28s. Something like that would still work in the Curare though I expect, probably better than the best servos of the 70's!
Time to create page: 0.408 seconds
