Joining stainless steel exhaust components
  • JRI
25 Feb 2016 08:53 #8088 by JRI
I am making a custom exhaust header for my Mig3 and 3W 55i using 25mm stainless components and flex header tube. What are the best materials and tools and techniques for soldering/brazing the parts and where is the best place to buy them from?
  • ronp849
25 Feb 2016 12:21 - 25 Feb 2016 12:24 #8091 by ronp849
Replied by ronp849 on topic Joining stainless steel exhaust components
You can use standard softsolder if you use Phosphoric Acid as a flux.
It is also easier than copper/brass because of the lower heat conductivity of stainless steel.
Last edit: 25 Feb 2016 12:24 by ronp849.
25 Feb 2016 15:10 #8094 by Phil Ford
Replied by Phil Ford on topic Joining stainless steel exhaust components
ronp849 wrote: You can use standard softsolder if you use Phosphoric Acid as a flux.
Where would one get the acid from? I have needed to weld stainlessitems before and have had to take it a specialist welding shop
25 Feb 2016 17:24 #8097 by DavidTappin
Replied by DavidTappin on topic Joining stainless steel exhaust components
Ron wrote "You can use standard softsolder", I tried soft solder in a similar situation years ago, it lasted about 30 seconds until the heat of the exhaust turned it extra soft, even actual runny!
How about silver solder?
  • ronp849
25 Feb 2016 18:07 #8098 by ronp849
Now I have read the original post properly, I can see that soft solder would not be suitable!!!
It seems like Phosphoric acid can be used with silver solder as well but I have not personally tried it.
www.bssa.org.uk/topics.php?article=150
28 Feb 2016 19:02 #8151 by kevinross
Replied by kevinross on topic Joining stainless steel exhaust components
Ive dome a lot of SS exhaust work and always use this flux - it does what is says on the label
I recommend this company for your Silver Solder
www.cupalloys.co.uk/medium-temp-silver-solder/index.asp
I have an Oxy / Mapp gas facilities if you want me to solder it for you.
The following user(s) said Thank You: JRI
  • JRI
28 Feb 2016 20:18 #8156 by JRI
Thanks Kev, I may well take you up on that Kind offer. Hopefully learn from the master how to do it myself ;)
  • JRI
28 Feb 2016 20:23 #8157 by JRI
kevinross wrote: Ive dome a lot of SS exhaust work and always use this flux - it does what is says on the label
Hi Kev, which of the silver solder diameter rods do you recommend?
28 Feb 2016 22:36 #8160 by kevinross
Most solders will work but your choice is based on your heat source. My oxy-mapp torch has unlimited heat but if you use a std propane torch the lowest melting temp solders are preferred but that means higher si content and carries a higher price
The smaller 1mm 650deg can be "ringed" around the flange. then it will run and fillet the join very well with plain Mapp gas.
ps - there is a small brazing hearth in "Franks stuff" if you're interested.
