Phase 5 by Chris Foss
7 years 7 months ago #15853 by
Replied by on topic Phase 5 by Chris Foss
I was keeping my involvement in this project quiet as I know I have a tendency to cause Jon to roll his eyes!
That's pretty neat Mike :cheer:
7 years 7 months ago - 7 years 7 months ago #15877 by MikeSeale
Although originally planning on a sparless wing, it had been pointed out that the aileron and flap servo bays create a weak point and have decided to add a spar just in case. I tried cutting slots for the spar caps but could not get consistent results using the hot wire. So have decided to cut a vertical slice out of the wing and then rejoin it with a pre-made spar. I've gone for 1/4 x 3/16 caps and 3/16 balsa shear web which is drying overnight.
Last edit: 7 years 7 months ago by MikeSeale.
7 years 6 months ago #15918 by MikeSeale
I cut the wings in half and re-joined them with the spar in place. A light pass with the sanding block levelled them with the foam (protected with masking tape.
Then cut out the servo bays prior to sheeting. I'll keep the foam blocks and cut a slice to line the floor of the bays later.
Then cut a slot for the servo wires.
7 years 6 months ago #15919 by JonTappin
Replied by JonTappin on topic Phase 5 by Chris Foss
That wing isn't failing Mike!
7 years 6 months ago #15922 by MikeSeale
JonTappin wrote: That wing isn't failing Mike!
I hope not!
A hard point has been added to the root of the wing. Once skinned I can drill through for the wing bolt.
Skins are 1/32 balsa secured using Gorilla (polyurethane) glue. Spread it thinly using an old credit card. I find it easier to use more glue than necessary then remove the excess. When spreading you need to move slow enough for a dam of glue to build up in front of the credit card. This ensures that the wood is wet all over. The edges and corners are particularly important.
Skinned cores are then placed back in the foam off-cuts and tapes all around to make sure the leading edges and trailing edges are tightly in place.
Finally some weights are added to hold it tight until morning.
7 years 6 months ago #15980 by MikeSeale
The wings came out of the skinning process and I've spent the last few days finishing off using aliphatic glue, so it takes a while between tasks.
A 1/4 inch leading edge and 1/16 hardwood trailing edge is added.
Ailerons and flaps are cut out and faced with 1/4 leading edge and 1/8 caps on each end. The wing trailing edge is also faced with 1/4
