Win Green - Tuesday 8th
09 Jan 2019 22:45 #18646 by MikeSeale
Replied by MikeSeale on topic Win Green - Tuesday 8th
MikeSeale wrote: Then a mixture of more thin CA, superphatic and aliphatic to glue the pieces back in
To explain...
Thin CA is great if you have a good fit and can hold pieces in place 'at a distance'. Not so good if you have to use your fingers because they will stick well before the wood.
Superphatic is nearly as thin as CA and wicks into the fibres very well if you have a close fitting joint. Great if you're gluing larger pieces that need sliding into position. You have a few minutes working time before it properly grips.
Aliphatic is used as a glue/filler on pieces that don't fit so well
10 Jan 2019 22:02 #18650 by MikeSeale
The hole in the rear fuselage was filled with a block of 1/8" balsa and then the whole lot smeared with lightweight filler
10 Jan 2019 22:04 #18651 by MikeSeale
And the fuselage is glued together. Again, where there are gaps due to missing balsa flakes, just cut a block of wood and glue it in. Fuselage has been coated in filler and awaiting sanding tomorrow.
10 Jan 2019 22:11 #18652 by MikeSeale
What looked like a complete mess 2 days ago is now just about ready for a final light sanding and then re-covering.
kevinross wrote: Ouch ! - Guess your revising the definition of superficial ?
I think a couple of evenings work is fairly light damage. What made it easy to repair was having all the little pieces of broken balsa to glue back together again - if you crash ALWAYS pick up all the pieces and handle the damaged model carefully in order not to create more damage.
kevinross wrote: PS - glad i'm too old for lessons with the Mike Seale school of driving this week.
Full time working since the crash. All damage repaired in my own time
11 Jan 2019 21:54 #18661 by 4Pedalsfly
Replied by 4Pedalsfly on topic Win Green - Tuesday 8th
Mike - Pleased to read repair is looking good & in the end damage superficial.
Illustrates on advantage of balsa / ply construction , once repaired, filled & sanded looks just
like new.
13 Jan 2019 01:18 #18671 by MikeSeale
The Orcrist will hopefully be re-maidened at one of the Wessex slopes later this morning. If anyone else fancies a slope trip let me know and you can join me as a guest.
