Night Flying
06 Feb 2017 13:23 #11856 by Chris73
Night Flying was created by Chris73
I have just ordered a few meters of Hobby Kings finest LED light strips so i can light up my shock flyer for night flying
I am going to do a simple blue on the top and red underneath (Unless anyone has a good reason not to do this???)
Can i just solder all of the red wires together and then all of the black wires together so i only have two connections??, the plan is run it of the balance lead from the flight pack
Just want to keep it really simple, its only a piece of foam :P
06 Feb 2017 14:59 #11857 by kevinross
Replied by kevinross on topic Night Flying
The soldering bits sound s good but i think they will need to be powered by a 3s pack - but no harm trying 2s
06 Feb 2017 15:40 #11858 by Chris73
Replied by Chris73 on topic Night Flying
Thanks Kevin, the shocky flys on 3S, so should be ok
06 Feb 2017 16:25 #11859 by MikeSeale
Replied by MikeSeale on topic Night Flying
Chris73 wrote: I am going to do a simple blue on the top and red underneath (Unless anyone has a good reason not to do this???)
Is it possible that the LEDs are bright enough to shine through the depron, rendering the 'blue-top' 'red-below' scheme useless? Blue-left and red-right won't matter if they shine through.
06 Feb 2017 17:29 - 06 Feb 2017 17:31 #11860 by Phil Ford
Replied by Phil Ford on topic Night Flying
I don't know HK's led finest so I'll make some assumptions. I assume they surface mounted leds on thin strip? Chris, wire a strip of leds in series. Yes Off 3 cells Yes. If HK say they are good for 3 cell then trust them..... :whistle: If they are for 2 cell voltages probably need a 220 or 270 ohm resistor on the positive lead on each strip.
Last edit: 06 Feb 2017 17:31 by Phil Ford.
06 Feb 2017 17:59 #11861 by Chris73
Thanks for the replies, they say they are good for 3 cell, so i guess we will find out
I think the foam will be thick enough to stop the light going through, although I must admit i hadn't thought about that, only one way to find out, stick them on and wait for it to get dark :evil:
06 Feb 2017 19:30 #11862 by kevinross
Sorry to dampen your enthusiasm but there a "fly in the ointment"
- Sorry but no flying after dusk at Cashmoor !
06 Feb 2017 23:32 #11863 by Chris73
Plenty of other places to fly a shocky after dark ;)
  • ronp849
14 Feb 2017 11:18 #11918 by ronp849
Replied by ronp849 on topic Night Flying
I fly mine behind the Blandford Tesco store.
I also use an old brushed motor controller (2amp rated) to control the LED brilliance.
The strips are normally configured in groups of 3 LEDs in series with a series resistor for each group. Hence they can be connected to a 12v power source without any current limiting resistors.
Ron
