Launch Pedal
19 Dec 2017 16:45 - 19 Dec 2017 16:46 #15063 by Phil Ford
Launch Pedal was created by Phil Ford
Have knocked up a bungee launch pedal. The pedal is secured by tent pegs at rear when in use and can also be cable tied to lower back pipe. Have come to a standstill though. :(
Trying to find some key rings, one biggun' for the pedal peg and a slightly smaller one for the model. Have searched in all our drawers, cupboards, tried Castles Ironmongery, B&Q, etc. Nothing! Ideas please?
Last edit: 19 Dec 2017 16:46 by Phil Ford.
19 Dec 2017 16:53 - 19 Dec 2017 16:55 #15064 by Brian
Replied by Brian on topic Launch Pedal
If there's a camping shop, they might stock small caribiners. You can get them on eBay too, lots of sizes and quite cheap. Split rings from a key cutting shop might do the biz.
Are you launching a model Phil, or just catapulting your old ones into the next field?
Last edit: 19 Dec 2017 16:55 by Brian.
19 Dec 2017 17:03 #15066 by Phil Ford
Replied by Phil Ford on topic Launch Pedal
Brian wrote: Are you launching a model Phil, or just catapulting your old ones into the next field?
:lol:
Hopefully launch the Super Wing and an old Habu EDF for starters
Key Cutting? Ah yes, we got a Timpson at Sainsburys. I'll try there.
19 Dec 2017 17:29 #15067 by kevinross
Replied by kevinross on topic Launch Pedal
i hope to make Cashmoor tomorrow so will pack my Hobbyking unit for you to assess. I'm sure a std keyring will suffice
19 Dec 2017 17:47 #15070 by DavidTappin
Replied by DavidTappin on topic Launch Pedal
Phil, while you're at it I think you will find that Kevin has also had some useful experience on the subject of prop rotation.
19 Dec 2017 21:19 - 20 Dec 2017 08:04 #15071 by Phil Ford
kevinross wrote: i hope to make Cashmoor tomorrow so will pack my Hobbyking unit for you to assess. I'm sure a std keyring will suffice
Kevin. Not sure whether the Wing is ready yet. lacking a launch pin I think. Anyway, my ramp is still laying the garage. I need to do a test set up before lugging it up to Cashmoor.
Last edit: 20 Dec 2017 08:04 by Phil Ford.
21 Dec 2017 16:39 - 21 Dec 2017 16:40 #15089 by Phil Ford
Did a test set up and made up lines today. I need to melt down the plastic a little bit more at the top end to save wing damage. And a "drag chute" ( a bit of rag) where the lines meet the bungee to slow and pull down the bungee after launch. Or is it really necessary?
Last edit: 21 Dec 2017 16:40 by Phil Ford.
21 Dec 2017 19:19 #15090 by kevinross
DavidTappin wrote: Phil, while you're at it I think you will find that Kevin has also had some useful experience on the subject of prop rotation.
I thought the prop direction was fine - i just had the model back to front !!
