Epoxy Glass Sheet
13 Mar 2019 18:23 #19056 by Dave Rogers
Replied by Dave Rogers on topic Epoxy Glass Sheet
Phil use cling film on the tube
The following user(s) said Thank You: Phil Ford, John Bannister
13 Mar 2019 19:24 #19057 by Phil Ford
Replied by Phil Ford on topic Epoxy Glass Sheet
Dave Rogers wrote: Phil use cling film on the tube
Not me Dave, it is John B. But thanks anyway. Did it work for you?
13 Mar 2019 19:53 #19059 by DaveBright
Replied by DaveBright on topic Epoxy Glass Sheet
It does work. I used cling film over blue foam to make the carbon retract blisters for my venom wing.
14 Mar 2019 08:41 #19062 by MikeSeale
Replied by MikeSeale on topic Epoxy Glass Sheet
An alternative to using cling film is baking paper. I made glass tubes for my Orcrist by wrapping baking paper around the carbon wing joiner. After wrapping it with glass I put heat shrink over the mess and once cured the tube came off the rod easily and the surface finish was smooth after the hear shrink was removed.
Time to create page: 0.402 seconds
