Freewing EDF Group
03 Jul 2019 15:20 - 03 Jul 2019 15:20 #20009 by JonTappin
I understand now how you managed to stretch it to 17 hours, didn't realise you were including 'mods'
Whether it's worth installing a rudder servo depends on how much you normally use your rudder in flight Brian. I tend to use mine a lot, plus I needed tail weight, so it seemed worth it for me. Here's a pic of my rudder install, in case you fancy doing it. If you remove the fan unit you can see a channel in the foam under it, it was reasonably easy to poke a wire from the fin to this point, then draw the cable through.
Last edit: 03 Jul 2019 15:20 by JonTappin.
03 Jul 2019 17:06 - 03 Jul 2019 17:07 #20011 by Phil Ford
Brian, Glad to hear you have joined the fray.
How did you stretch it to an hour? This is me - connect the RX temporary to ESC to verify fan is going in right direction. Nope! So swap two leads round. (5 mins) Fit receiver and connect servo/throttle leads. (1 minute) Fit wing using screws about 10 minutes (as holes did not line up perfectly). Sip tea. (10 secs) Mix up some of my own 4 minute epoxy, dry fit tail end. Glue tail end bits. Sip tea for 5 minutes. Epoxy has gone off. Fit control horns (20mins). Switch on RC radio gear, check servos work, and right direction, adjust clevises for neutral control surfaces (15 mins). Create some rates/expo on X9D TX. 20 mins. Set up throttle range. Done! Take to field and master launch method - a bit longer.:lol:
A few days whilst fiddling and modding by some error I cannot fathom :whistle: I put a servo lead into the fan. Wait four days for replacement from NL. Now refitted I may add.
I used Nano Tech 2200 3 cells 35C. 200 gms weight. sits in middle of battery bay
Last edit: 03 Jul 2019 17:07 by Phil Ford.
03 Jul 2019 18:12 #20013 by Brian
Thanks for the pic of the rudder mod Jon. When I've got the first flight out of the way, if the MIG survives, I'll have a go at fitting a rudder servo.
Phil, thank you for such a comprehensive description of your workshop activities. Getting leads tangled in the fan is a nuisance. I did exactly the same with my Tony Nijhuis 42" Hawk. I ran it up to test the system, I'd forgotten to cinch the battery strap. Fortunately, the damage was a shredded balance lead with amazingly, no shorts or fire. Waited a long time for HK to produce a Dr Mad Thrust rotor, but in the meantime, I had the exciting task of regenerating the balance lead and plug. That's when I found that lead colours aren't common to all LiPo batteries. Thank goodness for a BangGood digital multimeter, a pencil and piece of paper, and starting from 0V on the black lead, adding leads in 3.7V increments. I think I aged a bit due to the anticipation of a big fat spark that would have put an end to all the effort. Fortunately the balance lead ended up OK, and after major surgery, the Hawk had its fan re-installed. Happy daze!
18 Jul 2019 19:00 - 18 Jul 2019 19:15 #20294 by Phil Ford
You may not be aware of this but a few weeks ago I ordered an upgrade EDF unit for my Sabre from MotionRC. When the package turned up just a day before the EDF Jet day, the box info was correct but the EDF inside was the standard version. :( Right! Back on to MotionRC and was surprised how quick they responded to my email with an apology. Said they would put it right. So, in the meantime I had to fit the standard version for the weekend in question.
Heard nothing else for ages until this afternoon, 18th July. The correct unit is now on it's way free of charge and P&P. :cheer: Problem is the Sabre was destroyed weeks ago. Does this mean I have to buy another? :lol:....
Last edit: 18 Jul 2019 19:15 by Phil Ford.
  • Simon O
18 Jul 2019 19:45 #20296 by Simon O
Replied by Simon O on topic Freewing EDF Group
You could always give it to me Phil. I have a pristine Sabre!
Simon O
  • AlanF
18 Jul 2019 20:26 #20297 by AlanF
You could go for one of the other Freewing 64mm jobbies- f18 perhaps or donate it to a worthy cause ;) I'll second your comments on MotionRC customer support; they are very good.
18 Jul 2019 20:28 #20298 by Phil Ford
Simon O wrote: You could always give it to me Phil. I have a pristine Sabre!
Simon O
:lol: Really? Not a chance but if you are in need of a replacement fan unit you know to where come. ;) And it WILL happen.
19 Jul 2019 06:51 - 19 Jul 2019 06:53 #20300 by Brian
When I wrecked my MIG's EDF, I contacted Motion RC but they didn't have any replacements. Got a cheaper replacement 64mm EDF from eBay. Then I found that the supplier also did 12 blade 64mm EDF units. The new MIG has a 12 blade fan, 50A ESC and a 4S battery. Now I'm too scared to fly it! HobbyKing do a niice 12 blade 64mm fan unit, but don't stock a motor that fits it, it took a lot of searching and I found a motor on AliExpress/BangGood. Fan and motor together still cheaper than Motion RC.
Last edit: 19 Jul 2019 06:53 by Brian.
19 Jul 2019 09:52 #20301 by Phil Ford
Brian wrote: The new MIG has a 12 blade fan, 50A ESC and a 4S battery. Now I'm too scared to fly it!
Well! you know where I live if you are "scared to fly it". :lol:
19 Jul 2019 15:44 - 19 Jul 2019 15:47 #20303 by Phil Ford
I have changed the thread title as it was not me to blame....:lol:
As I have a nice free upgrade EDF fan unit with nothing to put it in I was in a quandary. So, after some serious deliberation I have ordered a Freewing Stinger 64mm (free P&P at the moment) and will drop the 12 blade into it.
Although I was hovering my mouse's left click over the Flightline Bearcat F8F but managed to restrain myself and the finances.
Last edit: 19 Jul 2019 15:47 by Phil Ford.
Time to create page: 0.372 seconds
