New T33
30 Sep 2020 17:23 #23411 by kevinross
Replied by kevinross on topic New T33
Obviously i dealt with many full size post birdstrike inspections and subsequent repairs but one aspect many people may not be aware of is the residual stench as generally the complete animal and its innards are splayed in the collision.
There doesn't appear to be any guts on your T33 so i guess you contacted the birds wing. Had you caught the body i suspect the damage would be far worse.
  • Mike Seale
30 Sep 2020 18:30 #23414 by Mike Seale
Replied by Mike Seale on topic New T33
Bad luck, Jon. But you can now join Jay in the exclusive bird strike club.
And Phil probably needs to change the title of this thread now!
30 Sep 2020 19:04 - 30 Sep 2020 19:04 #23417 by Phil Ford
Replied by Phil Ford on topic New T33
Mike Seale wrote: Bad luck, Jon. But you can now join Jay in the exclusive bird strike club.
But I was thinking of Hitchcocks "The Birds" and revenge so Jon ought to check if there are hundreds of Crows on his TV aerial and phone lines tomorrow :lol:
Last edit: 30 Sep 2020 19:04 by Phil Ford.
30 Sep 2020 19:07 #23418 by DaveBright
Replied by DaveBright on topic New T33
Very lucky!! Not an exclusive club one would set out to join. Poor T33, poor bird!!
  • JonTappin
30 Sep 2020 21:22 #23421 by JonTappin
Replied by JonTappin on topic New T33
Kevin Ross wrote: Obviously i dealt with many full size post birdstrike inspections and subsequent repairs but one aspect many people may not be aware of is the residual stench as generally the complete animal and its innards are splayed in the collision.
I've started on the repair today and opened the wing up, no guts found! Even at a distance I a saw a large object drop away, so the bird was probably pretty intact after the impact.
The spar, at the tip is where the damage finished, so structurally it looks ok, but I will be thoroughly checking everything.
The following user(s) said Thank You: kevinross, Phil Ford
  • JonTappin
20 Oct 2020 16:05 #23493 by JonTappin
Very happy to say the T33 is now repaired and ready to go again :)
  • JonTappin
20 Oct 2020 16:06 #23494 by JonTappin
Closer look
  • JonTappin
20 Oct 2020 16:09 #23495 by JonTappin
The original construction is a foam sandwich, so I molded a carbon skin on the outside of the wing with some release agent, then used it as a internal liner.
  • JonTappin
20 Oct 2020 16:10 #23496 by JonTappin
Skin bonded in place and additional balsa support ribs added
  • JonTappin
20 Oct 2020 16:13 #23497 by JonTappin
I also molded a new carbon leading edge
Time to create page: 0.394 seconds
