Minus Thermic
18 Sep 2016 22:53 #9931 by Chris73
Minus Thermic was created by Chris73
Not in the same league as Pete's builds but thought I would share my progress so far on my mini sloper
Couple of hours this evening with a laser cut kit, a pot of CA and some sandpaper, and hey presto the fuselage is done :cheer:
18 Sep 2016 23:15 #9932 by MikeSeale
Nice work, Chris. I'm going to have to pull my finger out to catch up.
19 Sep 2016 07:41 #9933 by simondean
Replied by simondean on topic Minus Thermic
Chris I'm surprised you didn't construct a jig , I'm sure Chris ( grommet ) will put you to shame.
19 Sep 2016 08:26 #9934 by Chris73
No jigs being used here, the general process on this build is
1) Glue it first
2) Look at plans
3) **** thats not quite in the right place
4) Attack it with sandpaper until it looks right
So far it has been no more difficult than line the parts up and glue them, sanding the wings to the correct shape could be a bit of a challenge but I will figure that one out when i get there (Or wait for Chris to build a jig and then steal it :lol: )
19 Sep 2016 09:54 #9935 by Phil Ford
Replied by Phil Ford on topic Minus Thermic
simondean wrote: Chris I'm surprised you didn't construct a jig , I'm sure Chris ( grommet ) will put you to shame.
Don't be concerned Boys. Gromit has produced a virtual jig in 3D CAD as we speak. If this is within 5 nano meters of the original concept then the jig will be produced on a new laser cutter purchased just for this job. The same laser cutter will then be used to cut out the required pieces to make an exact copy of the one Chris H is sticking together. It should not take long with today's technology......... :lol:
19 Sep 2016 17:39 #9938 by flyingpete
Like your style Chris B) that's the way I tackle builds!!! don't have time to build jigs :woohoo:
19 Sep 2016 19:15 #9940 by Chris001
I'm still studying the plans :)
19 Sep 2016 19:59 #9941 by Chris73
Managed to get a bit more done tonight, first job was to cut (bodge) a groove in both wing halves to accept the wing tube. I used a little bit of 5 minute epoxy to hold the tube in place, I then used some white glue to join the two wing halves together, and a bit of thin CA to tack them in place while the glue dried.
I then added the bottom piece of the wing and glued in the ribs. Final job was to glue on the ply wing root. Just needs a good sanding and one wing is done
19 Sep 2016 20:01 #9942 by Chris73
A few more pics
19 Sep 2016 20:54 #9947 by Chris001
Chris73 wrote: ...first job was to cut (bodge) a groove in both wing halves to accept the wing tube...
Chris, I'm surprised you didn't use a Granny's Tooth for that job ;) Nice scissors by the way, I've always thought you probably favour floral patterns in the privacy of your own home.
Time to create page: 0.381 seconds
