Minus Thermic
15 Dec 2016 20:14 #11192 by Chris001
Thanks Pete, I think this little glider was designed by someone on a computer where everything is perfect, unlike real life!
I've just done the hinges, I'll be taking out shares in Sellotape shortly :)
15 Dec 2016 20:22 #11194 by flyingpete
Chinese robots have little fingers B)
15 Dec 2016 22:52 #11196 by Chris001
Just linkages and canopy releases to go... I think & hope.
16 Dec 2016 07:31 #11198 by MikeSeale
Most/all models have those frustrating moments when you're building them. The size of this model creates a few more frustrating moments than it should. But it looks great now and you'll forget about all those hours wasted once you're flying it.
16 Dec 2016 09:41 #11200 by Phil Ford
Replied by Phil Ford on topic Minus Thermic
MikeSeale wrote: and you'll forget about all those hours wasted
:lol: I would rephrase that Mike or was it intentional?
16 Dec 2016 17:20 #11209 by MikeSeale
Having seen your "Christmas Story", all I'd say is "if the cap fits..."
16 Dec 2016 17:27 #11210 by JonTappin
MikeSeale wrote: Having seen your "Christmas Story", all I'd say is "if the cap fits..."
:lol:
16 Dec 2016 18:17 #11213 by Phil Ford
:lol: Yes maybe but my story only took a few minutes. ;)
16 Dec 2016 20:05 #11221 by Chris001
MikeSeale wrote: ...A solution would be to use very short elevator horns, but I had already cut them to 8mm and decided that even shorter would not be acceptable because:
1. Shorter horns would give limited 'grip' for the heatshrink and
2. Shorter horns would result in MORE elevator movement than needed and I would have to dial down the throw using travel limits, and this would reduce my resolution
So the elevators were removed and a couple of mm cut from the ends in order to increase the gap. With hindsight, only 1mm was needed
Hi Mike, did you settle on 8mm horns for both elevator and ailerons? And will you do the same on the Acro, or maybe go longer on the ailerons?
16 Dec 2016 22:40 #11224 by MikeSeale
Go longer if you can
