Minus Thermic
08 Dec 2016 22:01 #11092 by MikeSeale
Chris001 wrote: That's going to hurt ;) I presume you clear heatshrunked (have I just made up a word) the RX after removing the cardboard outer wrapper?
I Kaptoned...thinner than heatshrunking it.
10 Dec 2016 18:55 #11126 by Chris001
I've just found a sure fire way to put myself into a bad mood. :angry:
Trying to cover the same wing tip, no less than five (insert expletive) times, after the failed second attempt I did the other wing tip first go. The icing on the cake is that the purple transparent film leaves the colour on the balsa when removing the film.
Thankfully both are now done, so I can get on with the Ailerons.
10 Dec 2016 19:09 - 10 Dec 2016 19:10 #11127 by Phil Ford
Replied by Phil Ford on topic Minus Thermic
Chris001 wrote: the purple transparent film leaves the colour on the balsa when removing the film.
Twern' t Profilm then? :P Cheapskate.... :lol:
Looks alright now though. That's good enough. I have had enough film swearing myself.
Last edit: 10 Dec 2016 19:10 by Phil Ford.
10 Dec 2016 19:11 #11128 by Chris001
Look here sunny, I splashed out on Hobby Kings finest... Yep I'm a cheapskate.
10 Dec 2016 19:50 #11129 by MikeSeale
Looking nice in the photos so it's worth the effort and cursing.
BTW,I've had transparent profilm leave colour behind...maybe it's a transparent issue, not a hobby king issue.
10 Dec 2016 20:44 #11131 by Chris001
Mike, is this the sticky tape I need?
www.t9hobbysport.com/diamond-ultra-clear-sellotape
10 Dec 2016 21:13 #11132 by MikeSeale
Yes. But they keep changing the name of it and Sellotape Super Clear tape is the same stuff and available from most Tescos and stationers.
10 Dec 2016 21:21 #11134 by MikeSeale
To avoid confusion, the sellotape is being used as a hinge tape for the ailerons and elevators. A few posts back I mentioned that I had used Kapton tape to wrap my receiver after removing the case.
Ebay link to Kapton
15 Dec 2016 18:36 #11185 by Chris001
I've gone my own way with installing the V tail, and cut little triangular pieces to fill in the void between the flat seat for the tail and the V of the tail, hopefully the photos will illustrate it okay. As far as the instructions go, they seem to suggest just CAing it in, but there is such minimal wood to wood contact area it just seems wrong.
The more work I do on this the more I'd like to get another one just to try and get it right next time, it's not gone together totally satisfactorily, but hopefully it will fly well on the slopes.
15 Dec 2016 20:09 #11191 by flyingpete
Great work Chris, far to fiddly for my liking :ohmy:
Time to create page: 0.375 seconds
