Minus Thermic
8 years 11 months ago #9940 by
I'm still studying the plans :)
8 years 11 months ago #9941 by Chris73
Managed to get a bit more done tonight, first job was to cut (bodge) a groove in both wing halves to accept the wing tube. I used a little bit of 5 minute epoxy to hold the tube in place, I then used some white glue to join the two wing halves together, and a bit of thin CA to tack them in place while the glue dried.
I then added the bottom piece of the wing and glued in the ribs. Final job was to glue on the ply wing root. Just needs a good sanding and one wing is done
8 years 11 months ago #9942 by Chris73
A few more pics
8 years 11 months ago #9947 by
Chris73 wrote: ...first job was to cut (bodge) a groove in both wing halves to accept the wing tube...
Chris, I'm surprised you didn't use a Granny's Tooth for that job ;) Nice scissors by the way, I've always thought you probably favour floral patterns in the privacy of your own home.
8 years 11 months ago #9948 by MikeSeale
Chris73...I don't think it will make any difference, but the leading edge wing halves have a top and a bottom cutout pattern that is different. You've joined the same pattern together so you have lost that criss-cross effect. I doubt that this will affect the strength, but it might mean you have one wing heavier than the other, so make sure you check the lateral balance before flying.
8 years 11 months ago #9949 by Chris73
Doh, I am sure it will fine
I will sand the leading edge and check i still have enough strength, if need be i can always add another few cross pieces in the holes
Thanks for the heads up though, I will finish both wings and then weigh them
Time to create page: 0.443 seconds
