DH Venom rebuild
09 Nov 2016 20:47 #10646 by flyingpete
Replied by flyingpete on topic DH Venom rebuild
Decided to cut the hatch in the nose to see what I am up against.Got rid of the sand and cement ballast and some dodgy woodwork.We now have a nice area to get everything up front and easy to get to.
09 Nov 2016 21:00 #10647 by 4Pedalsfly
Replied by 4Pedalsfly on topic DH Venom rebuild
Pete - Great work and so impressed by your work rate.
From the type of ballast used combined with the paint thickness I'm drawn to the conclusion that the original
builder of the model was a Plasterer by trade.
10 Nov 2016 08:17 #10648 by flyingpete
You could be correct Colin!! The paint on the venom is thicker than the underseal on my landrover :S
10 Nov 2016 09:40 #10649 by DaveBright
Replied by DaveBright on topic DH Venom rebuild
Great stuff mate. The big old nose access hatch is great to see. Is there room for two levels?
10 Nov 2016 10:05 #10650 by flyingpete
DaveBright wrote: Great stuff mate. The big old nose access hatch is great to see. Is there room for two levels?
Don't see why not
10 Nov 2016 11:57 - 10 Nov 2016 11:58 #10651 by flyingpete
Wings finished and a good fit back on the tubes,
Ready for glassing
Last edit: 10 Nov 2016 11:58 by flyingpete.
10 Nov 2016 15:56 #10652 by flyingpete
Time for the booms,fair bit of internal damage.The plan is to cut some new formers for the booms and glue a phenolic tube inside.The booms will slide on the tubes epoxied in place.The formers will be solid with just one hole for the servo wires as I need to get max strength.
10 Nov 2016 16:01 #10653 by flyingpete
Formers cut and will be fitted in the booms with f/ g resin and will finish that tonight.Tomorrow fit the booms and the venom is back together.
10 Nov 2016 16:21 #10654 by JonTappin
Replied by JonTappin on topic DH Venom rebuild
Are you making the booms removable Pete, would be relatively easy as you are installing the phenolic tubes?
10 Nov 2016 17:29 #10655 by flyingpete
JonTappin wrote: Are you making the booms removable Pete, would be relatively easy as you are installing the phenolic tubes?
No Jon, the tubes are not matched pairs and have a little play but that will be taken up when they are epoxied in.
