DH Venom rebuild
  • Banned
  • Banned
8 years 10 months ago #10652 by flyingpete
Replied by flyingpete on topic DH Venom rebuild
Time for the booms,fair bit of internal damage.The plan is to cut some new formers for the booms and glue a phenolic tube inside.The booms will slide on the tubes epoxied in place.The formers will be solid with just one hole for the servo wires as I need to get max strength.
  • Banned
  • Banned
8 years 10 months ago #10653 by flyingpete
Formers cut and will be fitted in the booms with f/ g resin and will finish that tonight.Tomorrow fit the booms and the venom is back together.
8 years 10 months ago #10654 by JonTappin
Replied by JonTappin on topic DH Venom rebuild
Are you making the booms removable Pete, would be relatively easy as you are installing the phenolic tubes?
  • Banned
  • Banned
8 years 10 months ago #10655 by flyingpete
JonTappin wrote: Are you making the booms removable Pete, would be relatively easy as you are installing the phenolic tubes?
No Jon, the tubes are not matched pairs and have a little play but that will be taken up when they are epoxied in.
  • Banned
  • Banned
8 years 10 months ago #10656 by flyingpete
The venom is back :woohoo:
8 years 10 months ago - 8 years 10 months ago #10657 by JRI
Replied by JRI on topic DH Venom rebuild
flyingpete wrote: The venom is back :woohoo:
Unbelievable work rate - but aren't you worried that the Bicycle you seem to have glued to the tail might affect the C.of.G ? ;)
Last edit: 8 years 10 months ago by JRI.
