Retro jet
22 Oct 2017 17:53 #14345 by DaveBright
Replied by DaveBright on topic Retro jet
So.... with poor weather today and I know Pete didn't enter the Great South Run - I should imagine the Retro Jet is twitiching and ready to fly??
26 Oct 2017 16:28 #14401 by flyingpete
Replied by flyingpete on topic Retro jet
Ok peeps back to the build, 6mm ply Shear webs glued in place and 12mm ply wing dihedral brace glued to one panel. The wing is then tack glued to the bench and sheeted with 2.5mm med balsa. The other wing panel slides over the brace and then glued.
Worth a mention at this stage, you should never use 5 min epoxy on a very high stress area like the wing brace. Always use slow setting 30 min epoxy which will take 12 hours to fully set. The other panel is then sheeted in the same way
26 Oct 2017 17:21 #14402 by Brian
Replied by Brian on topic Retro jet
Thanks Pete, nice to see some robust woodwork.
26 Oct 2017 18:22 #14403 by Chris001
Replied by Chris001 on topic Retro jet
Hi Pete,
What's your choice of glue for sheeting the wing, and is the reason for taking the wing to the bench so that it doesn't distort as the glue dries, or to prevent it moving around?
26 Oct 2017 18:48 #14404 by flyingpete
Chris, The ribs have tabs on them to give the correct washout so the wing must be pinned or glued to the bench. My favourite glue for the sheeting is aliphatic resin, as it is a fast grab adhesive and dries quickly. Another excellent glue for wing sheeting is the foaming gorilla adhesive.
28 Oct 2017 11:36 - 28 Oct 2017 11:37 #14424 by flyingpete
Both wings have been sheeted on the top and joined . Turn the wing over and plane off the tabs on the ribs. A good rub down to make sure everything is nice and smooth then sheet the bottom. 9mm balsa leading and trailing edges glued on then give the whole wing a good sand using P150 glass paper. For a bit of added strength a 150mm x 200 Gramme fibre glass bandage is added around the wing joint. For the resin I have used Z-poxy finishing resin.
Last edit: 28 Oct 2017 11:37 by flyingpete. Reason: Text
30 Oct 2017 18:38 #14454 by flyingpete
Won't bore you with the covering process, but final bits of detail being added
Time to create page: 0.335 seconds
