Stearman build
10 Apr 2020 17:49 #22045 by kevinross
continued
Dave
The motor will be the Saito FG60
10 Apr 2020 22:09 #22048 by DaveBright
Replied by DaveBright on topic Stearman build
Excellent.
22 Apr 2020 21:17 - 22 Apr 2020 21:19 #22232 by kevinross
Progress has been limited recently but now had some time in the workshop. Fabricated the parts for the fwd Cabane struts, doesn't look much but many hours went into planning and producing these.
The first 2 pic shows just the alloy exterior trims in place.
The third pic shows the exterior trims and the internal struts which will provide the strength. They will be laminated from 2 lengths of 0.5mm Stainless either side of 2mm T6 alloy. The accompanying drawing is a reduction from the full size drawings. I know they have 6 rivet holes and i have only 4 but i have to apply some practicality.
The last pic is the jig i made to drill the fixing holes
Last edit: 22 Apr 2020 21:19 by kevinross.
23 Apr 2020 06:58 #22235 by Brian
Thank you for the detailed description and photos Kevin. Until now I'd assumed that the cabanes were either bent up alloy strips or piano wire covered in balsa. It'll be a shame to cover up all that work!
23 Apr 2020 10:02 #22236 by kevinross
Hi Brian - Solid alloy cabanas are the norm for this and similar models, but due to some hardware shortages i thought why not make life difficult and build more scale like cabanes - hence all this work and brain overload.
04 May 2020 07:45 - 04 May 2020 07:46 #22338 by kevinross
While Mike builds a whole glider in a week, my attempts to scale up and re-engineer of the Cabane Struts is slowly progressing
Last edit: 04 May 2020 07:46 by kevinross.
04 May 2020 13:41 #22347 by JonTappin
Replied by JonTappin on topic Stearman build
Lovely work Kevin!
07 May 2020 21:29 #22381 by kevinross
Ive rigged the Cabane with temporary wires to establish final lengths.
Making these mods may not seem difficult but must say its the most challenging modelling task ive ever done. However, I delighted thats its incredibly rigid.
07 May 2020 22:53 #22382 by Brian
Now that really is a labour of love Kevin, lovely work!
08 May 2020 08:39 #22384 by kevinross
Feeling quite pleased as i laid my head on the pillow last night then had a sudden brainrush. Due to my build changes there is No point in finalising the strut rigging until i have at least built all 4 main spares. They are rectangular boxes with built in tapers or Furrings ( item 133 in pic 2) to set the dihedral. So i need to align the spar tips not the centre section.
