Stearman build
5 years 4 months ago #22406 by kevinross
spar box now aligns with centre section
5 years 4 months ago #22408 by Phil Ford
Finally getting progress underway.
5 years 4 months ago #22447 by kevinross
Small diversion as the rudder hinging has been bugging me. The design uses Robart H/D pin hinges which are fine but they would protrude almost 1/2 their length.
So reworked using paxolin stub hinges and removable wire pin
5 years 4 months ago #22449 by JRI
Hi Kevin, how thick is the paxolin plate, what diameter is the hinge (I assume it is hollow brass) and does it need lubricating?
5 years 4 months ago - 5 years 4 months ago #22450 by kevinross
JRI wrote: Hi Kevin, how thick is the paxolin plate, what diameter is the hinge (I assume it is hollow brass) and does it need lubricating?
could
the pax plate is approx 1/8. with 1.7mm holes for 16swg piano wire. The brass tube is a sliding fit at approx 1.9mm bore. but you've just stirred my ageing brain. I was going to fix the wire to the rudder and allow the wire to turn in the paxolin. (then if wear occurs i could bush the paxolin Perhaps i could bend the wire 90deg and locate in the rudder sternpost and grease the wire to turn in the brass tube
Last edit: 5 years 4 months ago by kevinross.
5 years 4 months ago #22451 by MikeSeale
Replied by MikeSeale on topic Stearman build
kevinross wrote: the pax plate is approx 1/8. with 1.7mm holes for 16swg piano wire.
Youve got to love this metric world we live in
Time to create page: 0.426 seconds
