Stearman build
4 years 9 months ago #23738 by Phil Ford
Those Hitec servos HS55** are programmable for overload, ATV, reversible using a Hitec programmer. I have one if you need it Kevin.
4 years 9 months ago #23739 by kevinross
Phillip Ford wrote: Those Hitec servos HS55** are programmable for overload, ATV, reversible using a Hitec programmer. I have one if you need it Kevin.
Thanks Phil - I might take you up on that before project finished. Its not being mixed with another servo so my Tx will cover ATV and reverse but it has about twice the required torque and scale type structures dont have the strength of a 3D model.
4 years 9 months ago - 4 years 9 months ago #23771 by kevinross
Apparently, pilots don't do it standing up and need one of these. Scaled the drawings down to get the seat outline. Soaked the .5mm ply to form on these tubes overnight.
Last edit: 4 years 9 months ago by kevinross.
4 years 9 months ago #23772 by kevinross
seat continued - Pilot still not happy !
The following user(s) said Thank You: JRI, Phil Ford, Brian
4 years 9 months ago #23773 by
Replied by on topic Stearman build
Has he had a Covid test Kevin?
4 years 9 months ago #23774 by JRI
Great pilot, what scale is he (and the model) Kevin?
