- Thank you received: 63
chris.m wrote: Resin W waterproof pva works well to
Topic Author
AlanF wrote: Nice one Phil, are you going to glue both surfaces at once or one at a time, epoxy, resin W, or gorilla glue - we're on the edge of our seats we need to know the results
Good luck for next week!
PVA? Now that's a thought, because it only sticks wood but has no hold on plastics, but the only thing I believe it has not got is some degree of flexibility which epoxy has.MikeSeale wrote:
Sometimes you do things the way you do because you've always done it that way. PVA certainly would be a lot easier to work with than epoxy...I'll give it a try on my next build/
Topic Author
Topic Author
PhilF51 wrote: Also is 1/2inch the standard distance between the hinge line and the horn screw?
Topic Author
If the hole in the control horn is 1/2 inch in front of the horn screw, yes. This will make the hole line up with the hinge line for the best linkage geometry.
