Provost
23 May 2015 14:42 - 23 May 2015 14:44 #4558 by kevinross
Replied by kevinross on topic Provost
As you may know Glens models hinges are similar. They use large diameter brass tube - It doesn't get sloppy but it migrates.
I think plastic bushes & piano wire is the way to go. An equivalent to the old micro mold snakes made for bowden cable inners would make a good bearing material.
My Decathlon (which i will have at Cashmoor tomorrow) uses 3mm carbon rod on ply hinges.
Last edit: 23 May 2015 14:44 by kevinross.
23 May 2015 15:49 #4559 by flyingpete
Flaps are similar construction but this time they are hinged on the bottom, thanks for the suggestion Phil and.Kevin,anybody got some snake.off cuts?
23 May 2015 15:53 #4560 by flyingpete
Forgot to say I'm going to use 3mm carbon rod for the hinge pin so the snake outer will have to fit that
  • ronp849
23 May 2015 16:52 #4561 by ronp849
Replied by ronp849 on topic Provost
What about very small shielded ballraces - the type fitted into some of the small brushless motors could work.
Ron
23 May 2015 16:57 #4562 by JonTappin
Replied by JonTappin on topic Provost
flyingpete wrote: Forgot to say I'm going to use 3mm carbon rod for the hinge pin so the snake outer will have to fit that
Wouldn't piano wire be better than carbon Pete, I would be worried carbon might wear over time? Small diameter snake outer would be a good option for the bearing though.
23 May 2015 17:15 #4563 by flyingpete
Thanks guy's, I'm open to all suggestions frank is bringing over tomorrow a selection of tubing etc so I will have a look at that.
I'm really enjoying the provost, it's a real builder's model which I love.The scale detail shown on the drawing is awesome and I want to reflect this in the finished model
23 May 2015 20:23 - 23 May 2015 20:24 #4568 by AlanF
Replied by AlanF on topic Provost
That's speedy work there, very impressive. Did you use aliphatic to butt join those balsa skins? I would have thought regular pva would be difficult to sand smooth.
Modelfixings sell a range of small bearings, you might find something of use there if you go that route.
Keep those pics coming :)
Last edit: 23 May 2015 20:24 by AlanF.
23 May 2015 20:37 #4570 by flyingpete
Alan, i use a top quality pva as it sands very well B)
23 May 2015 21:06 #4571 by AlanF
I just remember having a nightmare sanding balsa glued with pva, and I cant remember which brand it was, evo stik resin w or deluxe materials or some such but, having switched to Titebond I found sanding much easier.
23 May 2015 21:50 #4573 by kevinross
Packed some samples for you to asses tomorrow Pete.
But looking at the last photos you posted, Piano wire & tube will be good for the twiddly bits at the end go the wing but the slowy downy bits will need some form of captive pin for which I have a cunning plan
Time to create page: 0.378 seconds
