Provost
26 May 2015 19:53 #4609 by flyingpete
And a very large brandy :woohoo:
27 May 2015 09:00 #4611 by flyingpete
Ok,first job is to glue together the four pieces to make up the engine box using pva.
Next up is to sort out the 41 individual ply parts for the fuselage, laser cutting on the ply parts is superb.
27 May 2015 12:11 #4615 by flyingpete
The fuselage crutch is built inverted over the plan.The lower formers ate tack glued in place,and lower stringers added. Once happy remove from plan,start filling upper formers.I.have temporarily fitted the engine box to aid alignment of front formers.
  • simonbloke
27 May 2015 12:39 - 27 May 2015 12:40 #4616 by simonbloke
Replied by simonbloke on topic Provost
Hi, looks brilliant, I wish I could build so quick and with such accuracy. :)
Can't wait to see it in the air.. :) :)
Very impressive so far
Simon M
Last edit: 27 May 2015 12:40 by simonbloke.
27 May 2015 15:55 #4618 by flyingpete
Added remaining formers and stringers and tailplane supports.will check alignment then go over with med cyano, fuselage completed.
Pics to follow
27 May 2015 15:57 #4619 by flyingpete
Pics
28 May 2015 20:21 #4637 by flyingpete
Nothing done on the provost today as i was on grandpops duty B)
The provost like my hurricane showed the elevator servos using very long push rods which in my mind is a big no no.So before i start sheeting the fuzz i am going to make a double servo tray and fit this under the fin with an access hatch .The rudder servo will be standard set up on heavy duty stainless wires.
I think this will help with the c of g as Frank has a lovely radial 60cc 4 stroke banger which will sound sooooooooooooooo scale up front.Another job on the agenda for tomorrow is fit the wing and glue the locating dowels and start the wing fairing
Pete
29 May 2015 11:17 #4644 by flyingpete
Elevator and rudder trays made and fitted
29 May 2015 14:55 #4651 by flyingpete
Perfect alignment of the wing locating dowels 1/4 square added to support the dowels and flooded with med cyano, the bottom wing sheeting can now be fitted
29 May 2015 15:42 #4652 by flyingpete
Here you go frank, starting to look like a provost B)
Time to create page: 0.797 seconds
