Royal Kit for Bleriot Mk XI
9 years 10 months ago #5774 by
Replied by on topic Royal Kit for Bleriot Mk XI
Been doing other stuff, ground maintenance, flying, young pilot training......
9 years 10 months ago #5802 by 4Pedalsfly
Replied by 4Pedalsfly on topic Royal Kit for Bleriot Mk XI
Phil-C wrote: Been doing other stuff, ground maintenance, flying, young pilot training......
Phil - Great hand launching technique , she's welcome to launch my gliders at Cashmoor.
No name's mentioned but can only be an improvement over some launches - nose high , tip stall but enough power
to get away with it.
Colin. A
9 years 10 months ago #5810 by
Obviously, I didn't post the numerous other shots.....
9 years 10 months ago - 9 years 10 months ago #5976 by
Starboard wing, nearly ready to cover. I decided to leave it as designed, so no extra spars, Mike.
I will complete the location tubes with laminating epoxy after the wings have been offered up to the fuselage.
You can just make out the built in washout at the tip.
Last edit: 9 years 10 months ago by .
9 years 9 months ago - 9 years 9 months ago #5996 by
After another 5 or 6 hours bashing and I nearly have both wings.
Been doin' some weighing, so tomorrow I will post expected weight etc. and seek advice on power plant.
Last edit: 9 years 9 months ago by .
9 years 9 months ago - 9 years 9 months ago #6025 by
The set up used in the videoed model above was an E-Flite E46 on 4S
I see Turnigy do a G46 which is similar, on the face of it.
The airframe will weigh 1553 gm or say 3-1/2 lb. That's including all completed parts, all wood and wire for the fus, the 5" spoked wheels, a bag of nylon two coats of dope and two JR591 servos.
The motor weighs 303 gm (0.67 lb), a Turnigy Nanotech 4s 2200 battery 239 gm (0.53 lb), a 60 A ESC say 1/2 lb
Add 1/2 lb for wires etc. Grand total weight should be 5.7 lb plus prop and driver.
Model is 51-1/2 in w/s and has a wing area of 564 in sq
Motor spec is here.
www.hobbyking.co.uk/hobbyking/store/__36...w_UK_Warehouse_.html
Am I on the right lines?
Time to create page: 0.391 seconds
