Royal Kit for Bleriot Mk XI
24 Sep 2015 12:08 - 24 Sep 2015 12:08 #6168 by Phil Ford
Replied by Phil Ford on topic Royal Kit for Bleriot Mk XI
A bit of a pain then? At least you know where you have beefed it up.
I assume your wife is not doing any of your washing this week due to a shortage of clothes pegs... :lol:
Last edit: 24 Sep 2015 12:08 by Phil Ford.
  • Phil-C
07 Nov 2015 18:18 #6886 by Phil-C
Replied by Phil-C on topic Royal Kit for Bleriot Mk XI
After a few weeks off to let my back and shoulder settle down (too much modelling), I have made a little progress. The power train has been purchased, delivered and wired up. All seems OK. Next job, install it all then complete the airframe.
07 Nov 2015 19:00 #6887 by Chris001
Replied by Chris001 on topic Royal Kit for Bleriot Mk XI
Did you by chance forget the obligatory photo my dear good fellow?
  • Phil-C
08 Nov 2015 10:24 - 08 Nov 2015 10:24 #6908 by Phil-C
You want a picture of a motor, ESC, battery and receiver and a bunch of wires? Take your own!
I have to fess up that on my first XT60 soldering job, which was pretty neat, I had to start again when I saw that the red wire should not go to the side that says (-)
I'll post a pic when they are mounted.
Last edit: 08 Nov 2015 10:24 by Phil-C.
08 Nov 2015 10:30 #6909 by Chris001
Sorry Phil, I thought you'd had it all installed, re-reading your previous post I realised you'd not got that far. I'll get me coat :oops:
  • Phil-C
08 Nov 2015 18:24 - 08 Nov 2015 18:26 #6914 by Phil-C
Not to disappoint, I took a pic of the electronics for the indoor Piper Super Cub, just for you, Chris. The washing machine components in the background are going in the Bleriot.
Two more fesses. Burned mi 'and on the iron and cut me finger in the prop.
Last edit: 08 Nov 2015 18:26 by Phil-C.
08 Nov 2015 18:58 #6915 by Phil Ford
Just as well you were not playing with the washing machine motor..... ;) You might never have been a handyman again!
  • Phil-C
09 Nov 2015 18:54 - 09 Nov 2015 18:54 #6922 by Phil-C
Did that one without prop. The little one, I wanted a current reading, so popped the prop on.
Tiny nick and the burn has gone already.
Found out today that it would have been easier to do the motor mount, with its 4 degrees of down thrust and side thrust, before I glued the firewall onto the rest of the fus.
Last edit: 09 Nov 2015 18:54 by Phil-C.
09 Nov 2015 19:49 #6923 by Phil Ford
4 degrees of down and right thrust. Sounds a fair bit much?
