03 May 2017 11:29 - 03 May 2017 11:30 #12743 by Phil Ford
AlanF wrote: I've had a thought Phil, you could let Chris keep the dust of your Curare B)
I was considering offering use of my Curare as I do have empathy for Gromit but as long as he recovers the film on it nicely and refuses to fly it across the Sun. Then I thought maybe not seeing as he has a less than "eye candy" Mythos as back-up plane :whistle:
Last edit: 03 May 2017 11:30 by Phil Ford.
03 May 2017 11:43 #12745 by JRI
Very sad to hear of the loss of the 'Atlas' - a lovely model.
Tip stalls seem to be less of a feature of sports models than it used to be, but it is still waiting to happen. I tend to avoid low air speeds and always try to keep a nose-down attitude on landing turns for fear of tip-stalls and I am also quite conservative on CofG for the same reason.
My advice is to get yourself a cheap hooler aerobatic model and thrash it around and you may find that getting yourself into and out of trouble becomes a more instinctive activity.
03 May 2017 16:33 #12750 by kevinross
Replied by kevinross on topic Winter build project: Wolfgang Matt’s ATLAS
Thats a B _ gg _ _ but the mental cure is your next build thread !
03 May 2017 17:00 #12752 by 4Pedalsfly
Replied by 4Pedalsfly on topic Winter build project: Wolfgang Matt’s ATLAS
Chris- Sorry to read the demise of your lovely Atlas,
See the thread on my rebuild of my Diamante , it is time consuming but very satisfying.
04 May 2017 23:40 #12762 by DavidTappin
Replied by DavidTappin on topic Winter build project: Wolfgang Matt’s ATLAS
Chris wrote
I won't be building another Atlas, not straight away anyway
Chris, that Atlas was a masterpiece, please don't rob us all of the opportunity to admire another one, we've all been there, some of us many times, and I write as an aeromodeller of nearly 70 years experience so I've had more time than most to make mistakes and sometimes the ego is even more badly damaged than the model.
Don't dwell on it too much, you know the advice usually given to the full size pilot after an unfortunate arrival - get straight into another 'plane and go fly.
One of Australia's most famous aviators, Charles Kingsley-Smith, said "An aviator's life is full of ups and downs, but the only hard thing about it is the ground".
I think what he was saying is that the enjoyment always exceeds the disappointment, there is plenty of enjoyment available.
05 May 2017 09:06 #12766 by Chris001
Thanks David,
The reason I said I would not build another Atlas, or at least not immediately, is that having built one, there is the possibility the second might not tun out as good, and there are also other classic pattern planes that might be interesting to build. I've not really thought about what to build, and don't anticipate rushing into anything straight way.
05 May 2017 11:04 #12767 by JonTappin
Hi Chris
Have you had any thoughts about completing that Touche airframe, that wouldn't take a massive amount of work and would suit the hardware from the Atlas?
05 May 2017 20:53 #12774 by Chris001
Okay, now I know things are bad... yesterday my karma was at -35 today it's at -34, someone must be thinking I'm in need of a little boost ;)
Anyway, it looks like I'm not being allowed to sulk for too much longer, or to slide into a period of [strike]deep research[/strike] procrastination while deciding what to build next. Instead this afternoon I was presented with three large sheets of paper which contained quite a few lines and a sprinkling of German words... the seed was sown. Thank you Mike.
05 May 2017 21:12 #12775 by flyingpete
Zeppelin!!
06 May 2017 07:17 - 06 May 2017 07:24 #12779 by JRI
Chris001 wrote: I was presented with three large sheets of paper which contained quite a few lines and a sprinkling of German words... the seed was sown. Thank you Mike.
Fokker Triplane .. .
Last edit: 06 May 2017 07:24 by JRI.
Time to create page: 0.506 seconds
