WMAC Group build - Impressivo
28 Oct 2013 23:45 #558 by DavidTappin
I just took another look at post 2 to refresh my memory and saw Mike's note re my building board, for the record our kitchen table is 6ft 6" by 3ft, I think that should do, it's only the consent for change of use that I lack!
David
29 Oct 2013 00:14 #559 by MikeSeale
I agree with Kevin and Jon that a cheap power system is desirable. In fact, I've done a little more research on the power setup and found an outrunner that could also work well according to the reviews.
Turnigy 2836-3200
Benefit over the inrunner is less weight at only 72g compared to 109g. Disadvantage is it only has a 3.17mm shaft (but the bearings are 4mm i/d, so if it bends you can replace it with a 4mm shaft). Also, having less thermal mass it might run hotter. But, there's only one way to find out so I've ordered both and will run some tests to find out whether one is better than the other.
Both motors have a kV or 3200rpm/v so should perform similarly. Reviews indicate that pylon props (5x5 for example) are turning at over 20,000 rpm on 3s. Some guys are running these motors on 4s and quote 38,000 rpm, so there's room for an upgrade in performance later if you feel the need :evil:
  • Stuartmck
29 Oct 2013 11:59 #560 by Stuartmck
Don't know if Mike got my pm. so will ask here to be added to the list.
Stuart
29 Oct 2013 12:39 #561 by MikeSeale
Stuartmck wrote: Don't know if Mike got my pm. so will ask here to be added to the list.
Stuart
I hadn't seen it, but you are on the list now!
29 Oct 2013 18:16 #562 by DaveBright
Count me in too please Mike. Looks like fun
29 Oct 2013 18:58 #563 by MikeSeale
You're on the list, Dave. That's a possible nine so far.
29 Oct 2013 22:09 #564 by JonTappin
If we ever get 9 up together, that's going to be exciting :evil:
29 Oct 2013 23:16 #565 by kevinross
re JT -
"If we ever get 9 up together, that's going to be exciting "
- Forgive me if i sound like a wimp but please can we each elect a unique main colour ??
30 Oct 2013 06:28 #566 by MikeSeale
wimp!
30 Oct 2013 06:52 #567 by DavidTappin
And a big number on one of the wings for the colour blind, and as for Mike's unkind repost I suggest sky colour for his.
David
Time to create page: 0.515 seconds
