WMAC Group build - Impressivo
30 Oct 2013 06:28 #566 by MikeSeale
wimp!
30 Oct 2013 06:52 #567 by DavidTappin
Kevin wrote
Forgive me if i sound like a wimp but please can we each elect a unique main colour ??
And a big number on one of the wings for the colour blind, and as for Mike's unkind repost I suggest sky colour for his.
David
30 Oct 2013 18:33 #569 by Chris73
Make them all identical :evil: :silly:
09 Nov 2013 19:00 #601 by MikeSeale
The motors arrived from Hobbyking on Wednesday...one of my quickest delivery times.
[IMG
As you can see, the outrunner is a lot smaller and lighter than the inrunner. However, I don't think weight will be an issue and it's only about 25g (1 oz.) difference so it will really come down to performance and longevity.
Neither motor comes with connectors solders on, but the outrunner does have 3.5mm bullets included as well as some heatshrink. So it's not only cheaper but it will save the cost of connectors if you use them. I used my standard 4mm silver bullets so if anyone wants the unused 3.5's let me know.
I've spent the afternoon converting an old model to accept these motors and will hopefully get out for a few test flights tomorrow. Brief test runs with a APCe 5.5x4.5 and an uncharged 2200 mAh Turnigy Nano-tech 35-70C pack gave 40A for the inrunner and 50A for the outrunner. I didn't measure voltage, but assuming 11V this equates to 440W and 550W respectively. My concern will be that the outrunner will get too hot and burn itself out quite quickly. Time will tell.
09 Nov 2013 21:24 #602 by JonTappin
Good work Mike, keep us posted.
09 Nov 2013 21:38 #603 by DavidTappin
Kitchen table at the ready, and planning my unique colour scheme is a work in progress *
The only downside I can see is, being a pusher, attaching ribbons for combat may a be a bit of a problem.
*As I'm in Germany I'm thinking big black crosses would be quite appropriate.
David
10 Nov 2013 07:48 #604 by MikeSeale
David Tappin wrote: As I'm in Germany I'm thinking big black crosses would be quite appropriate.
David
Just remember that some German crosses are less appropriate than others!!
10 Nov 2013 17:59 #612 by Phil Ford
Mike, the outrunner is supposedly good (HK specs)for 650 watts so 550 watts should be okay. The ESC though really need to be generous and get adequate cooling somehow. I would suggest that the outrunner would more capable of self cooling than the inrunner.
10 Nov 2013 18:08 - 10 Nov 2013 19:52 #613 by MikeSeale
Tests were completed successfully(ish) today. I'd converted an old MPX twinjet by cutting off the two old brushed speed 400 motors and adding a mount for the new motor. I used some of the old wiring partly because it was already in place and partly because I don't think I had enough silicone wire for the job.
First flight was with the inrunner which clocked 23,500 rpm at 50A on a 5.5x4.5 prop. Performance was good but the model was all over the place - too twitchy - because it used to fly a lot slower with only about 150W compared to over 500W. I landed and introduced some expo and it flew a lot better. Then the ESC cut and I was forced to land. Inspection revealed that the old wiring (PVC covered) had melted and created a short circuit. I fixed that with some heat resistant tape and put the outrunner in. This showed 65A and 24,500 rpm on the same 5.5x4.5 prop. It was not clear if this extra power actually resulted in any better performance because I was having to run at part throttle most of the time anyway. A second flight with the outrunner on a 6x4 prop ended with the wires melting together again. Outrunner also sounded a little rough when you turned the prop by hand indicating that a bearing might have gone.
So I put the inrunner back in and insulated the wires again for a couple more flights using the 6x4 prop. Current was up to 58A and rpm down to 23,000. The extra thrust made the launch and climb out a little better and with throttle management I'm not sure I could tell the difference in flight.
My preference is still the inrunner after these tests. Kevin wondered if a less powerful motor would be better if you hardly ever needed/wanted to use full power. My thoughts are that the power is nice to have and that putting on a smaller prop is the way forward. I will try the following next weekend if weather permits and if hobbystores in Southampton have them in stock:
4.1x4.1
4.5x4.1
4.7x4.2
4.75x4.75
These will give less thrust but hopefully still enough. They will also give more rpm and less amps.
I suppose the next question is when do we want to place an order...before Christmas or after?
Last edit: 10 Nov 2013 19:52 by MikeSeale.
10 Nov 2013 19:52 #614 by MikeSeale
PhilF51 wrote: Mike, the outrunner is supposedly good (HK specs)for 650 watts so 550 watts should be okay. The ESC though really need to be generous and get adequate cooling somehow. I would suggest that the outrunner would more capable of self cooling than the inrunner.
On a freshly charged 3s 2200 battery I was seeing 65A (measured), so assuming 11V from the battery this is 715W. So the outrunner is not running within spec. The inrunner wasn't inside spec either on the 6x4 but it was (just) on the 5.5x4.5. If I get one of the smaller props it will be fine.
As for self-cooling, I'd be happy to hear the logic but I always assumed inrunners cooled better. This is because the copper is in direct contact with the can, the the heat can conduct out easily. The inrunner has the copper in the middle and some of the heat has to pass through the magnets before it gets out.
Time to create page: 0.380 seconds
