Frsky - Taranis
  • tommy
27 Nov 2013 20:30 #728 by tommy
Replied by tommy on topic Frsky - Taranis
Looks like I bought the right TX then because I don't own anything expensive !!!!
It arrived today so will be getting it sorted over the next couple of weeks. Will let you know how I get on.
Tom
02 Dec 2013 20:32 #753 by MikeB
Replied by MikeB on topic Frsky - Taranis
The Taranis beeps and displays the RSSI value when in range check mode. In normal flying there is a voice warning when the RSSI is getting low.
During development, FrSky were prompted to fit 'proper' gimbals. They developed good quality, ball bearing gimbals.
Phil: I've seen quite a few reports of 'expensive' radios having interference problems and FrSky just working at the same site.
Colin A: I think you have that the wrong way round. My DJT module beeps in range check mode when in telemetry mode, but doesn't beep in non-telemetry mode when in range check mode.
There's a whole forum for the open source firmwares , and lots of info on the Taranis there.
Mike.
  • tommy
03 Dec 2013 20:12 #755 by tommy
Hi MikeB
Have been sorting out my taranis and wow, what a piece of kit I'm very impressed. You cannot beat a £1.85 sensor that plugs straight into RX and tells me via speech from the TX what my lipo pack voltage is doing whilst in flight, wow again.
I'ts complicated with all the various options but the simple stuff is still simple. Have got it to do what my optic did with no problems. Just trying to get my head around the extra bits and EEPROM programming / downloading via laptop. It seems that every single function is programmable.
Will probably be tapping you up for some info Mike on the odd occasion, I hope you don't mind.
Tom
  • simonbloke
04 Dec 2013 11:30 #756 by simonbloke
Replied by simonbloke on topic Frsky - Taranis
Tom.
This tx sounds good, will have to follow your experience as i will need to upgrade one day.
Simon
23 Dec 2013 08:15 - 23 Dec 2013 08:16 #895 by Phil Ford
Replied by Phil Ford on topic Frsky - Taranis
Here are the specifications. Personally I am not convinced to buying one at present.
When the first batch was released, dealer T9Hobbysport was virtually sold out immediately. Many enthusiasts had pre-ordered this new transmitter to ensure they were the first to have the Open Source software powered controller. Designed to be fully programmable by the user. However, it takes some "learning curve" to get to grips with it. See T9Hobbysport. WMAC member Mike Blandford, who wrote some of the software will be talking about this TX at Club Night on January 10th.
The most important aspect for any transmitter is maintaining a rock solid connection with the receiver. FrSky is well known for the frequency hopping ACCST technology taking advantage of the entire 2.4GHz band resulting in excellent range and reliability. FrSky knows many things can affect the connection between Transmitter and receiver so RSSI (receiver signal strength indication) is incorporated into all telemetry receivers. The Taranis transmitter is continually monitoring the reception quality at the aircraft. Taranis will alert the pilot before signal quality becomes critical. In addition to RSSI, Taranis has other safety features.
Receiver Lock allows you to lock a specific model in the transmitter to one and only one receiver. No more flying with the wrong program selected.
Taranis has three different types of Failsafe. 1 - Hold last known commands, 2- Goto a programmed state (cut throttle, flaps down, etc. 3- No output. (Triggers flight controllers with "go home" feature.) The RSSI feature means you probably won't ever use the failsafe.
Voice Alerts Just like having a copilot, the transmitter will give you voice alerts on speaker or through the headphone jack. Count down timers, low voltage warnings, landing gear down, thermal mode entered, etc. can all be set up with human recorded voice of your creation, or sound packages shared online from other hobbyists
The open-source software for the Taranis has been developed by hobbyist’s in the R/C community. The programmers of the transmitter’s firmware and companion software which runs on Linux, Windows, and Macintosh are very receptive to input and requests from users
With 60 model memories, tons of mixes, 9 flight modes, sequencing, servo speed, programmed delay all kinds of triggers, and the ability to assign any channel to anything, it is hard to come up with something this radio can't do. With this level of complexity, you would think the programming would be a real nightmare, but thanks to the forward thinking of the open source community, we can set up and test our programs on our favorite computer (PC, Mac or Ubuntu), it even features a handy set up wizard that will take care of most of the work! But they also made it easy to share programs freely via the USB port, or micro SD card on the back of the Taranis.
Are you heavily invested in another RF system? No worries, the Taranis actually has a normal JR style module on the back that will accept modules for other transmitting protocols. In the model setup you simply tell the system if you are using the external module, and it shuts down the internal FrSky module. Now you can use your Futaba, Spektrum, JR and other receivers if you have a transmitter module that fits in a JR style module bay.
Features:
  • Full Telemetry RSSI alarms (warns you of signal reception problems before disaster can strike)
  • Self test of the transmitter antenna
  • 16 channels (more when combined with external module)
  • 60 model memories
  • 64 mixers, 9 flight modes
  • 16 custom curves with 3-17 points each, 32 logic switches
  • Voice or custom sound alerts
  • USB and SD card slot for system expansion
  • Long range system capable of up to 3 times the range of current 2.4 systems
  • Quad bearing gimbals that are silky smooth
  • State-of-the-art open source software
  • Large 212 X 64 backlit LCD screen
  • Real-time data logging
  • Receiver lock (program locked to aircraft - limited to FrSky receivers running PXX protocol)
  • JR Style module bay for additional RF modules and so much more
  • Selectable flight mode (1, 2, 3, or 4)
  • 2 timers, count up or down, throttle %, talking, etc.
  • Trims - Adjustable from course to extra fine with extended and exponential trims
  • Standard trainer jack
  • ARM Cortex M3 32-bit 60MHz
  • Integrates with CompanionTX – a FREE computer program that is a transmitter setup buddy. CompanionTX (Windows/Mac/Linux) is used to set-up models with the wizard, save, edit and share your models and settings as well as simulate your transmitter or model setup.
  • USB connection for firmware upgrades, sound editing, R/W to the microSD card and integrate with CompanionTX
  • Sticks and pots can be calibrated by the end user
  • Multiple language support (Radio arrives configured for English language)
Last edit: 23 Dec 2013 08:16 by Phil Ford.
23 Dec 2013 18:14 #901 by Chris73
Replied by Chris73 on topic Frsky - Taranis
So why are you not convinced Phil?? If its as good as you just said it was it sounds like a bargain
23 Dec 2013 23:57 #903 by Phil Ford
The specs are indeed excellent as you can see from my copy and paste input. Really have to make careful comparisons with two top notch JR transmitters that I am considering. The new 11ch and the Zero. The former is DSM and DSMX and is also getting rave reviews and the latter, the Zero which I tend to favour with the use of modules so can switch from DSM2, DMSS and possibly any other future frequency/modes. I am thinking 5.4Ghz!
The Taranis has voice prompts. A bit gimicky or useful? The case looks very JR but does it have quality dual ball bearing gimballs for long life and precision?
Taranis - The price is very attractive but somewhere some corners have got to have been cut, regardless of open source software. So, does this mean that the top brands are charging 75% of the cost of a TX just for their software which cannot be that much different. The main chip is generic with some slight mods probably from brand to brand.
No-one wants to throw good hard earned cash at a piece of essential equipment and wish they bought the other. The jury is out in my case! ;)
04 Jan 2014 23:00 #1011 by 4Pedalsfly
Replied by 4Pedalsfly on topic Frsky - Taranis
If anyone is considering ordering one, just spotted one for sale on the BMFA website.
Guy lives in Dorset BH12PQ and was supplied by T9.
Colin.A
05 Jan 2014 10:37 #1012 by Phil Ford
Um! So why is he dumping it on the market already? :huh:
Maybe someone should contact him and try to extract why selling so soon!
05 Jan 2014 10:51 #1013 by MikeSeale
Replied by MikeSeale on topic Frsky - Taranis
Hey, Phil. I think we get it...you don't like the sound of the Teranis and won't be buying one. But how about leaving your negative comments off this thread because I don't believe it is helpful for anyone who is considering buying one. Now, if anyone has first-hand negative comments that's fine. I've been using FrSky modules and receivers for a couple of years without issue and have followed the Teranis thread on RCGroups for a long time too. FrSky does not have a reliability or quality issue. Yes, the case will feel plasticy next to a top of the range JR, but if you compare it with a transmitter of similar price it will feel just as good. As for the components...if you think that JR/Spektrum are using superior components in their kit then I honestly believe you are wrong...the DX6i was recalled due to failing pots and the scroll-wheel is a known weak point, for example.
For the record, the guy selling is an ex-WMAC member and slope glider pilot. He uses a MPX Evo transmitter and gave the Teranis a go and decided it was not for him. This was taken from the BMFA website, so we cannot be sure what he means by this
Time to create page: 0.331 seconds
