Futaba 8J
07 Nov 2017 20:43 #14538 by MikeSeale
Replied by MikeSeale on topic Futaba 8J
Simon O wrote: O.K. I have plugged the servos directly into channel 1 & 6. Servo on 1 works fine, the servo on chan 6 not responding at all.
You need to tell your radio that you are using two servos for ailerons. Look at the index of your manual that came with the radio and look for how to set up a model with two aileron servos. At the moment it sounds like this function is inhibited or not assigned which is why there is no output to channel 6.
07 Nov 2017 20:54 - 07 Nov 2017 20:56 #14539 by JRI
Replied by JRI on topic Futaba 8J
Page 49 of the 8J manual (flaperons)
Last edit: 07 Nov 2017 20:56 by JRI.
07 Nov 2017 21:05 #14540 by 4Pedalsfly
Replied by 4Pedalsfly on topic Futaba 8J
Simon - If the programming is similar to my Futaba FF9 - set it up in "Flapperon " programme and you can adjust each servo accordingly,
the "Flapperon" programme automatically mixes them.
If required, direction can be reversed in "Reverse" programme.
When 2 aileron servos are fitted I always set them up in different channels so each can be adjusted seperately.
Look forward to seeing the "Waco" flying.
  • Simon O
07 Nov 2017 21:07 #14541 by Simon O
Replied by Simon O on topic Futaba 8J
Thanks Mike and John.
I think I get the gist now having read the instructions a couple of times! I will now try it on the tranny.
Simon
Time to create page: 0.276 seconds
