FrSKY Taranis X9E
7 years 6 months ago - 7 years 6 months ago #16083 by
Replied by on topic FrSKY Taranis X9E
Dead right!
Stuart
Last edit: 7 years 6 months ago by . Reason: Too many capitals
7 years 6 months ago #16084 by Brian
Replied by Brian on topic FrSKY Taranis X9E
I don't think that either of you will get packing rings now, better stick with your old fashioned R/C gear.
7 years 6 months ago #16087 by
kevinross wrote: If somebody provides me with a diementioned drawing - i'll see if i have suitable alloy material to machine some for you. - with free click and collect @ Cashmoor
Thanks Kevin, I'll hope to have a drawing for you later in the week, and you can see if it's doable.
All the best, Chris
7 years 6 months ago #16092 by Brian
Improved "suspension" arms. They don't fold, but they do fit inside the carry case.
7 years 6 months ago - 7 years 6 months ago #16093 by
Hi Brian,
Where did you get the arms I was looking to modify a transmitter mitt for the X9E and a set of these would be just the ticket.
Would also be interested to know how you attached them to the X9E, although I don't have an issue with the current ones, but did have to change the strap, the clips were just too small with cold fingers on top of a hill with snow coming at me ;)
If JRI reads this he'll probably link to this video:
7 years 6 months ago #16094 by Brian
Chris they are Horus neck strap supports from T9HobbySport. I retained the main alloy channel, and two clamp plates from the original build. The alloy channel has to be drilled 6mm dia. to accept the fatter arms. Much easier to "hook on". I didn't know whether to publish this, I didn't want to upset "Trig", or his broom.
