Spectrum DX6 Fault
  • FlyBuster18
05 Aug 2018 16:14 #17312 by FlyBuster18
Replied by FlyBuster18 on topic Spectrum DX6 Fault
John, What do you take me for as ex RAF! You might have to take the official line but your assessment of my TX is incorrect all that is wrong with it is crossed up settings. After reading the handbook in greater detail I have managed to get it to work correctly with my Plane and I have not had to re-bind them!!
05 Aug 2018 16:21 - 05 Aug 2018 16:22 #17313 by 4Pedalsfly
Replied by 4Pedalsfly on topic Spectrum DX6 Fault
FlyBuster18 wrote: No Colin I have not Re-bound my TX. But surprise my TX works ok direct to my model. To check that it works to the club slave I will have to make a visit to Cashmoor.
Thank you
Ernie
Ernie - I am confused - when you last trained I understand you buddied with the Clubs DX 6e transmitter ( no buddy lead) - was your transmitter the MASTER or the SLAVE ?
Thanks
Last edit: 05 Aug 2018 16:22 by 4Pedalsfly.
  • FlyBuster18
05 Aug 2018 16:22 #17314 by FlyBuster18
Hi Colin, No I have not re-bound my TX to plane, but as you can see by other posts the TX is now working to the Plane ok.
thank you Ernie
  • FlyBuster18
05 Aug 2018 16:23 #17315 by FlyBuster18
The Master
05 Aug 2018 16:42 #17317 by 4Pedalsfly
FlyBuster18 wrote: The Master
Ernie - Since your tx was the MASTER was a buddy lead being used with one of the club's older txs being the SLAVE ( ie not wireless ) ?
Thanks
  • FlyBuster18
05 Aug 2018 18:43 #17318 by FlyBuster18
Colin originally my TX was set up by Mike Searle to work to one of the clubs older TX"s Both as mode 2. This always works well until a member wanted to train me with him using Mode 1 on my TX as master and me using Mode 2 on the same club slave. thats when it went to pot!
05 Aug 2018 22:36 - 05 Aug 2018 22:38 #17320 by 4Pedalsfly
FlyBuster18 wrote: Colin originally my TX was set up by Mike Searle to work to one of the clubs older TX"s Both as mode 2. This always works well until a member wanted to train me with him using Mode 1 on my TX as master and me using Mode 2 on the same club slave. thats when it went to pot!
Ernie - Assuming your TX was set back to Mode 2 correctly there should no longer be a problem since the Club have dedicated Mode 2 & Mode 1 Spectrum DX6e
wireless transmitters for training purposes.
I fly Mode 1 & would name & set up your model in the master TX model memory then bind it to your model.
You would then bind your own TX to the receiver in the Master transmitter & away we go - no buddy lead.
Having read the other postings it would appear that there is a problem when a Buddy Lead is plugged into your transmitter,
- that needs resolving.
Last edit: 05 Aug 2018 22:38 by 4Pedalsfly.
  • FlyBuster18
06 Aug 2018 16:45 #17328 by FlyBuster18
I will have to check it may be a faulty socket !
