DSX9 Settings Changed?
6 years 6 months ago #18641 by Chris73
Replied by Chris73 on topic DSX9 Settings Changed?
Phil Ford wrote: DSX11 and Zero owners. According to the manual if a SD card is inserted you can save settings to the card. Manual is a bit ambiguous but can I assume you can copy card data back to the TX?
Yes you can, the manual for the zero is quite simply a waste of paper
Google is usually your friend for anything Zero related, there is loads of info out there
Time to create page: 0.214 seconds
