Gyros - Help !!
6 years 2 months ago #20381 by
Replied by on topic Gyros - Help !!
May be an issue with the orange stabiliser for Colin. It only works with Futaba s-fhss protocol.
  • 4Pedalsfly
6 years 2 months ago #20390 by 4Pedalsfly
Replied by 4Pedalsfly on topic Gyros - Help !!
Thanks to Brian, Phil & Simon for your comments & offers.
Brian's "Taranis " is really a no-go, since I would finish up with a
tx for one model only.
Best option seems lower rates & expo - then give it another go
with a couple of spotters on standby !!
I fly Mode 1 which is not suitable for Jon to fly it.
6 years 2 months ago - 6 years 2 months ago #20391 by John Bannister
Replied by John Bannister on topic Gyros - Help !!
Colin I think that is the way to go, In my opinion stabilizers are good in windy conditions on the normal aircraft that we fly when you have time to test it at altitude and have time to switch it on and off if you haven't got everything set up right, but in the situation you were in fighting to control it the last thing you would have been thinking of would be to switch stabilization on or off. I have only saved a plane once by switching on self leveling mode.
I have a KK2 from hobby king which is independent of transmitter type which you can try but I would suggest you try it on a slower plane first. It is meant for controlling a Quad copter but can be used with conventional aircraft. Has its own screen for setup.
Last edit: 6 years 2 months ago by John Bannister.
6 years 2 months ago #20393 by
HK sell a stand alone Quanum gyro specifically for planes. Fits all receivers. comes with all leads etc. £13.00 ish from Global warehouse. Good reviews.
6 years 2 months ago #20395 by DaveBright
Replied by DaveBright on topic Gyros - Help !!
We’re talking elevon and throttle only? If assistance is required why not bind to a mode 2 tx, get it wrung out then pop it back on your tx Colin and copy the rates across?
  • 4Pedalsfly
6 years 2 months ago #20396 by 4Pedalsfly
tommy wrote: HK sell a stand alone Quanum gyro specifically for planes. Fits all receivers. comes with all leads etc. £13.00 ish from Global warehouse. Good reviews.
Tom - Good to hear from you, long time no see.
Thanks for the info, still considering my options.
Time to create page: 0.308 seconds
