Rebuild of E-flite "diamante 25e
  • 4Pedalsfly
17 Apr 2017 09:48 #12604 by 4Pedalsfly
Replied by 4Pedalsfly on topic Rebuild of E-flite "diamante 25e
Now onto the fuselage front section, this was badly damaged the best option was to make a new set of parts.
Shattered formers and other components were tacked together with cyno to provide templates.
The assembly sequence is shown in the attached pics.
Next stage will be to add motor box, cross sheeting and undercarriage reinforcement.
Four pics here ( max allowed ) last two in next message.
  • 4Pedalsfly
17 Apr 2017 09:51 #12605 by 4Pedalsfly
Last two pics attached.
  • 4Pedalsfly
24 Apr 2017 10:07 #12643 by 4Pedalsfly
Basic front fuselage section is now complete, motor box added.
Next stage was to join the rear & front sections, after a bit of head scratching I
decided the best option was to use the wing as a jig.
Wing was set at zero incidence and fuselage halves aligned and also set at zero incidence.
Once satisfied all was o.k the joint was glued and left overnight to fully set.
  • 4Pedalsfly
24 Apr 2017 10:08 #12644 by 4Pedalsfly
Last pic
24 Apr 2017 10:31 #12645 by JonTappin
Replied by JonTappin on topic Rebuild of E-flite "diamante 25e
It's getting there Colin, looking good!
24 Apr 2017 17:21 #12650 by flyingpete
Replied by flyingpete on topic Rebuild of E-flite "diamante 25e
Superb work Colin, most would have binned the model, just goes to show what can be achieved with a bit of balsa bashing.
24 Apr 2017 18:02 #12654 by Phil Ford
Replied by Phil Ford on topic Rebuild of E-flite "diamante 25e
flyingpete wrote: most would have binned the model
Yep! ;)
Excellent job Colin.
24 Apr 2017 18:06 #12655 by JonTappin
flyingpete wrote: Superb work Colin, most would have binned the model, just goes to show what can be achieved with a bit of balsa bashing.
Sad these days that only a few people will ever feel the satisfaction of resurrecting a bin bag job!
  • 4Pedalsfly
17 May 2017 15:20 #12878 by 4Pedalsfly
Progress continues at a slow pace, fit between wing and fuselage improved.
Filling and final sanding of fuselage complete and the airframe is now
ready for covering.
The original cowl and canopy were badly damaged in the crash, a "Wanted" ad
was placed on the B.M.F.A. website and a guy came up with both in much better condition than mine.
Amazing what us modelers hang on to.
Last pic shows new canopy & cowl in place.
  • 4Pedalsfly
17 May 2017 15:31 #12879 by 4Pedalsfly
Last pic shows replacement canopy and cowl in place.
