Quanum Observer Rebuild
6 years 9 months ago #18468 by Phil Ford
Replied by Phil Ford on topic Quanum Observer Rebuild
I did have a half hearted start with it Dave. Judi was not impressed with the mess/dust though. That's why I have had a go with the present version for now.
6 years 9 months ago #18471 by Brian
Replied by Brian on topic Quanum Observer Rebuild
Make yourself a sanding board Phil, 4ft X 1ft 1/8" hardboard base, 2" X 1" glued to form the sides, pre drill one side to take tube from Missus F's vacuum cleaner, Now you should have a shallow open "box" structure. Get a piece of perforated hardboard, you know the stuff, 1/8" holes all over it. Glue some spacer blocks onto the base as supports for the perforated top. Glue the perforated top on. Finally drape some of that soft plastic net stuff that stops your salad sliding around the tray when you're having a snack in front of the TV. I made mine when there was a complaint about a fine film of balsa dust floating on a certain persons glass of G+T. Alternatively, you could borrow mine.
6 years 9 months ago #18473 by Phil Ford
Thanks for that info Brian. Although going that route of jigs will place me in "Grommets" category of jig building and lot's of jibes and fun poking....:lol: :evil:
6 years 9 months ago #18474 by Brian
That can't be bad can it?
6 years 9 months ago #18475 by Phil Ford
Chris doesn't think so ;) .
Any way I have modified the floor (again) and I have a cunning plan that may just work this time round. :unsure:
6 years 9 months ago #18476 by Brian
Does your "cunning plan" involve a turnip Baldrick, or am I in the wrong era?
Time to create page: 0.982 seconds
